How to Boot from USB Flask Disk / Drive on an (old) BIOSTAR A880GU3 Mobo ?
sk89
Hi all, I am newbie here..
I picked up an old (2010-2011) mobo (a Biostar A880GU3) for cheap from closed-down netcafe a year ago in 2019.
I didn't got the time to tinker with it until very recently.
So I managed to set everything up with an unused ATX case, plugged everything in, managed to get it boot into BIOS etc.
But I was unable get it to boot from a USB Flask Disk --which I have bootable Live Linux image there.
I have searched : "how to boot BIOSTAR A880gu3 from usb"
Got this: https://www.biostar.com.tw/app/en/support/faq_content.php?S_ID=709
The BIOS menus are similar, but a bit different from my mobo's.
This is what my mobo's boot and BIOS looks:
This is how the BIOS looks:
As you could see, there seems to be no option for booting from USB drives.. eventhough a bootable USB is plugged, it still won't boot (just goes to pic 2 and 3 there), pressing F9 during POST also does nothing (also goes to pic 2 and 3).
Can anybody tell me, how to boot from USB flash drives using this mobo ?
Thxx
sk89
press f12 see if it gives you a boot menu.
try another usb drive.
make sure bios is up to date. http://biostar-usa.com/app/en-us/mb/introduction.php?S_ID=516#download
F12 iirc is to flash the BIOS.
The USB works fine on both of my laptops. I had YUMI installed with Windows installer and a few Linuxes there.. I gotta find another free USB to flash then. We'll see..
I will try the BIOS update route when I got a free unused USB on my hand. Probably ltr in the day...
pendragon1
Extremely [H]
press it, find out.
yeah, ive had old systems be picky with usb drives that work fine in everything else. try another.
Reactions: sk89
GiGaBiTe
Is there a "hard disk boot order" somewhere in the BIOS setup?
I've had endless trouble with motherboards that treat USB flash drives like hard disks. They won't boot to them because there's a sub menu where you have to move the flash drive to the top of the disk order to take priority over normal hard drives/SSDs.
AMIBIOS from 2009 should support USB boot. If you can't see it, try unlock hidden options with Shift+F1 / Alt+F1 / Ctrl+F1 while in the BIOS menu.
Suppose to be in Advanced > USB Configuration.
USB devices should appear in Boot > Removeable Drives.
sk89
press it, find out.
You're right.. I tried an old Lexar 4GB pen drive that has only DBAN in it. It boots..
I then flashed it (the Lexar 4gb) again with Ubuntu with YUMI, tried it. 1st time works, 2nd time failed again (like 3rd pic), 3rd time success again.
I still don't kno why precisely.. it could be either the problem with the pen-drive, the board, or just the USB connection.. The pen-drive that always fails was a few months old 16GB Toshiba (prolly fake one too i am not sure...)
Anyway to select USB boot, I have to press F9 during POST. If the mobo can read the USB fine, it will display the boot drive selection (I didn't snap it, but i think you'all got the point)
The problem is partially solved for now. I hope the board does not give me any other problems..
Thx for all who chimed in and especially pendragon1.
sk89
I created the flash disks using YUMI (google it). The drives are still formatted using MBR partitioning.
sk89
Yeah, I know, already used it b4.
But it only supports a single bootable Live CD on a pendrive. I would hv to keep multiple, if I wanted to play with multiple OSes.
I already found the problem. It's not YUMI. It's either the flash-disk, or the board, or just the USB connections. Read my prev-posts.
toast0
Older systems get pretty picky when disks are slower to respond during init. Sometimes doing something dumb to make startup slower helps -- like setting it to probe for more hard drives or run the memory check more, etc.
Reactions: Nobu
Nobu
Yeah, I'm guessing it takes too long to initialize USB & the drive sometimes. Might get it to boot more reliably if you connect the drive directly to the onboard usb (rather than a hub), and/or disconnect other usb devices, or try other ports.
sk89
Ok. I'll take that in mind.. I already used the onboard USB on the back actually.. I'll see if I can slow down the BIOS startup maybe...
pendragon1
Extremely [H]
look for a boot or hdd delay, set it to 5 seconds.
