Just as the topic says, how do u bleed the circuit ? I dont wanna pay the 30 dollars for the swiftech bleeding kit, so id like to know how to do it on my own. Links to tutorials would be great too if its too hard to explain.
I would have a spot in the line that you could make the highest point in the system and cut the hose there or have 2 ends meet there. Pull those 2 ends apart and fill from one tube end and let the water chase out the air to the top of the other tube. Once you have it mostly filled, submerge both ends in a bucket filled with water. Turn the pump on and let it flush out the bubbles. Once your satisfied, put the line ends back together while they are still under water.
