How to assign my hard drive letters??? help please
Discussion in 'Operating Systems' started by lemmy, Jul 19, 2005.
  1. lemmy
    lemmy Limp Gawd
    460
    Oct 23, 2004
    Hi I just installed 2 hard drives attached to my PCI RAID SATA controller, i installed everything properly, i can go to device manager and see both the hard drives, but i don't see the drives in the my computer area, any clue what to do?
  2. jpmkm
    jpmkm That Ain't Mayo On My Lip...
    5,774
    Oct 30, 2001
    Did you partition and format them?
  3. lemmy
    lemmy Limp Gawd
    460
    Oct 23, 2004
    nope how do i do that?
    is there a way to partition then in windows? i don't have my windows cd, and these are new hard drives so do i need to format?
  4. jpmkm
    5,774
    Oct 30, 2001
    Oh I think you can go to computer management(in the administration control panel) to partition the drives from within windows. Or open a command prompt and use fdisk(does windows still have fdisk?) Then once they are partitioned you can go to 'my computer' to format the drives just like you would format a floppy disk.
  5. lemmy
    lemmy Limp Gawd
    460
    Oct 23, 2004
    do i want these as dynamic disks?
    i found a intialize and convert disk wizard
  6. lemmy
    lemmy Limp Gawd
    460
    Oct 23, 2004
    I went to disk management and it says Disk 1/2 are unallocated?
  7. jpmkm
    5,774
    Oct 30, 2001
    So allocate them. There should be something in there that allows you to create a partition on the drive. I wouldn't go dynamic. Not worth it. Just do regular partitions and be done with it.
