So my Seagate HDD started making not normal sounds lately. It failed a couple of the Seatools tests so I will send it back under warranty. I just ordered my first SSD drive. The idea is to do a fresh install of Win7 on the new SSD, transfer some files from the failing HD and then when I get it back from warranty service I will use the repaired HDD as a backup drive.
How do I add the SSD as the C: bootable drive?
do I unplug the HDD, install the new SSD then plug the old drive back in to transfer files? Can I just transfer files between the two drives or will I need to use DVD or flash drive? I know there is cloning software but Im not really doing that with a reinstall of win7.
Never had more than one HD in my computer so I'm unfamiliar with the steps involved.
Thanks
Thanks
