How much heat does the average projector output? Is it more than a gaming pc ?
Nobu
It depends on the tech, but I think more than anything it's just really concentrated around the light source.
A halogen bulb will put out anywhere from 100-400w of heat (maybe more in larger or brighter projectors), depending on the rating of the bulb. An LED lamp will put out similar amounts of heat (maybe a bit less), but it'll be much more concentrated (so higher cooling requirements per watt output)
Archaea
Watts are a term that can be related directly to heat.
many projectors have ~250 watt bulbs.
probabably most PCs idle around 50 watts, and in game use about 100 watts + graphics card power use. (Say total 175-350 watts for most systems in game)
The projector is going to generally add more heat to the room. In a big room you’ll not notice it. In a small bedroom you might. Think of it like a very small space heater.
ng4ever
The projector is going to generally add more heat to the room. In a big room you’ll not notice it. In a small bedroom you would. Think of it like a very small space heater.
Anyway to prevent the extra heat in a small or big room ? Other than a portable or window ac ?
Nobu
You could vent it...that's about the only other option unless the projector is in an entirely separate room.
Archaea
Most projectors have an eco mode which saves of about 20% light output, which would reduce heat and energy consumption. What is your use case? I can’t imagine that a projector is going to significantly heat any room it is used in much more than a HDTV, game console, or PC. It would take hours to raise the temperature in a small room even a couple degrees. I mean we used to use 60 watt light bulbs. Lots of rooms had three 60 watt light bulbs (180 watts) and you never thought - I better not use the lights or it’ll get hot in here. I suspect you are worried about nothing, unless your room is very small or doesn’t have HVAC service.
Nobu
Most projectors have an eco mode which saves of about 20% light output, which would reduce heat and energy consumption. What is your use case? I can’t imagine that a projector is going to significantly heat any room it is used in much more than a HDTV, game console, or PC. It would take hours to raise the temperature in a small room even a couple degrees. I mean we used to use 60 watt light bulbs. Lots of rooms had three 60 watt light bulbs (180 watts) and you never thought - I better not use the lights or it’ll get hot in here. I suspect you are worried about nothing.
I have, but I really don't like being hot. It's more noticeable when the AC is off or set high, especially with no fan running. Not as bad as 4-6 120w bulbs in a vanity light fixture, but still noticeable.
