Contemplating the $400 upgrade. I run 1080p on my monitor, and I play Overwatch and possibly some BF1.. how much benefit from the 1070 over my old R290? Or should I hold out?
Yep, I'm on a 4ghz 2500k. Wondering how much life I'll be able to get out of it - I'm thinking one more card soon and then I'll probably be due for a new system in another 2-3 years?
I hear from the rumor mill that the new Kaby Lake i5's will start at 4.0GHz+. Of course I'm going to wait for Zen since I waited 5 darn years already and it's right around the corner. But I hope and pray that those Kaby Lake processors will be an across the board 25% - 40% upgrade over what you and I have. Not a flash in the pan one game upgrade; an overall, every application upgrade.
/pray for performance!
lol, same here. For main or power system I want a major upgrade. My I7 system performance is nice but not significantly better then the FX one.I hear from the rumor mill that the new Kaby Lake i5's will start at 4.0GHz+. Of course I'm going to wait for Zen since I waited 5 darn years already and it's right around the corner. But I hope and pray that those Kaby Lake processors will be an across the board 25% - 40% upgrade over what you and I have. Not a flash in the pan one game upgrade; an overall, every application upgrade.
I have to run OW @ 1080p with my GTX780 (comparable, faster) on medium settings to get the frames needed for 144hz.....He mentions Overwatch and BF1 @ 1080p, where yes, it *is* overkill, especially if he's on a 60hz monitor. BF1 beta already performed anywhere from 70-100fps on my OC'd 970 maxed out, default resolution scale. Overwatch goes from 90-120fps. Both games at 1080p. Minimums are excellent, beyond 60fps.
But for other games, I stipulated that it will be a large jump (even at 1080p) as long as it can be fed properly - definitely not overkill. For example, Witcher 3 should stay mostly above 60fps @ 1080p even with HairWorks on, but still may not be locked.
