I need to provide internet connectivity to about 8 users via satellite. Its out in bfe and other than dial up (not even any local numbers with that) Satellite is the only half broadband option I can get.
This setup is not only going to have to provide for up to 8 users. Most likely never all accessing the net at one. Maybe one person at a time or two.
But the distances are going to put a strain on things. We are talking about at times a total run of about 500 feet. Now I know that about 100 meters is the max I can go without signal loss. I plan on going from the satellite/modem/main computer/router about 100 meters to a switch. which then will run between 100-200 feet to each location.
Now heres the biggy. Most of this is going outside in the ground, There are 6 separate buildings two buildings with two connections and two single connection buildings.
This is all on one property whos total dimentions are about 600x600ft
There will eventually be about 16-20 pc's across the property. And I imagine there will have to be at least one or two more satellites to provide adequate bandwidth as one satellite will provide only 1.5mbs.
Anyways I would muchly appreciate some input on this. It'd be great to know if this will or wont work before we go and spend all the money on the hardware.
thanks
thanks
