How many USB buses does a motherboard have?
Discussion in 'Motherboards' started by LucasG, Jan 30, 2019.
  1. LucasG
    LucasG Gawd
    625
    Jul 2, 2004
    So basically I do a lot of streaming and upgraded my computer in order to have better USB support than my MacBook pro apart from other things, the story here is I tried moving around USB connections all over my motherboard and apparently it only has 1 usb hub. In order to have more I have to buy a PCI card that will provide me space for 1 more camera, due to the amount of bandwidth they consume. I would of thought it had more than one considering it has USB 2.0, USB 3.0 and USB 3.1.
    I have an ASUS PRIME Z390-A
  2. bwang
    bwang Gawd
    935
    Aug 6, 2011
    Z370 and older boards with USB 3.1 Gen2 have a second hub, since the 10Gbps ports are provided by an Asmedia chipset connected over PCIe. However, keep in mind on the consumer platforms, everything except the x16 graphics slot(s) is connected to the chipset lanes, which share a single x4 upstream connection to the CPU - depending on how hard you stress the I/O you might run into issues.
  3. LucasG
    LucasG Gawd
    625
    Jul 2, 2004
    I'm just running two Logitech C922x and it's a pain to have them both working properly on Wirecast sometimes because the USB hub gets overloaded according to the errors reported by Wirecast, it asks to change to a different USB bus.
  4. bwang
    bwang Gawd
    935
    Aug 6, 2011
    If the C922x outputs uncompressed video, two of them will overload the hub, but if there is any sort of compression (even MJPEG), the hub should have enough theoretical bandwidth to handle them.
  5. LucasG
    LucasG Gawd
    625
    Jul 2, 2004
    I was researching for the cameras that do the encoding directly on the camera. Would this help with USB bandwidth usage? I found Logitech's datasheet but it only talks about CPU and power utilization: https://www.logitech.com/assets/45120/logitechh.pdf Maybe I could get several of these?
