How many radiator space I need for water cooling
Lucky75
Hello guys,
I have Mo-Ra 420 PRO with 420 and 280 Alphacool radiators.
Did I need all of them for better and low noise cooling ?
I can sell 420 and 280 radiators and build only with big one or keep them all for better temps.
Tsumi
If you have the space for it in your case, you might as well keep what you currently have. A 420 + 280 radiator will cool any single GPU setup quietly.
Ready4Dis
Yeah, a 420+280 is a lot of cooling. What are you trying to keep cool and how much overclocking are you doing? It really depends on what you're running on how much radiator area/volume you need. A single 480 rad is pretty good for most builds, but again highly dependant on what you have and what you are trying to do.
VanGoghComplex
If you're keeping the MO-RA, your other two radiators will do nothing for you but add loop restriction. You're already well beyond the point of diminishing returns with that MO-RA.
