Happy Hopping
- Jul 1, 2004
how much is the extra 1200 rpm fan?
~18€how much is the extra 1200 rpm fan?
They're the new Chromax fans, you need to buy them extra.hwy, how did you buy the above CPU cooler? I can't find NH-D15 or D15S that c/w the black fan. They all come w/ the medium brown color fan. Did you buy the black fan extra and just swap out the brown color fan?
Also, is that a piece of plastic on your video card? did you do it yourself?
I was thinking of the Noctua but I'm now thinking of the Cooler Master Air Maker 8
https://noctua.at/en/products/product-line-chromax
You can make a hovercraft with them and finally sail away.that's what I thought. So it doesn't make any sense. If I buy the extra fans, what do I do w/ the old brown color fans? They should have a CPU cooler that c/w the black color fan
Why don't you go watercooled? My goodness, all those monies on FANs! Go water cooled!!!!
Radiators don't require fans?
Then don't use it. I mean, there's lots of things already inside your computer than can cause cancer, but whatever.the "wet water" or equvialent can cause cancer. do
If your loop is set up properly (drain valves, silver coin, etc) then all you really need is a can of air and a $1 jug of distilled water. It's not that bad.Also, maintainence of water cooling is a headache. W/ air, just a can of air will do
No. This is why it is conventional wisdom to only use one type of metal in the loop. Copper is the traditional and preferred choice, both for it's thermal conductivity and natural corrosion resistance, though aluminum parts are becoming more prevalent and will pose no problem as long as they aren't mixed with any non-aluminum parts.but what about ionization of water? when it loops to different type of metal, from Al to Cu to Zn etc.? Don't they need that additive and mix it 50 -50 w/ distilled water?
You can control that. Watercooling companies (the reputable ones, at least) advertise exactly what their components are made of. And it's not your video card itself that has to be the right metal, it's the GPU block.but you can't control that. You go buy a video card, if it's not the same metal you have, you won't buy it? And for that matter, you'll somehow find out what kind of metal such and such brand names use? and you'll handicap yourself by not using such and such brand because it's not the same metal?
Well, I'm not the only one. You read on page 1 of this thread that others has short circuit their video card. I think they should make these CPU cooler in a thinner (elongated) sharp instead of square
what's wrong w/ Cooler Master cooler? I thought they ranked 1 of the best
Nothing wrong with his rig, just LOOK at all those fans!
OK, they look nice but you show me a better performing 140mm fan (unassuming you were referring to me and not the cooler master video).
I have had numerous high-end "highly ranked" Coolermaster coolers and they all sucked. The best of the lot was the 212,, and it only cooled decently by running dual fans at very loud very high speed. And then it was way below par.
And it is not just their cooling performance, Their mounting, both motherboard and fan attachment were sub-par. Lots of hype, no results. Never again.
If you are looking at reviews at frostytech, forget it. Their numbers, and other review sites, do not match reality,
I was looking at the spec. of the Master Air Maker 8.
the spec. shows a max. of 24 dB. They are the Silence FP fans
The MTBF is long, 160,000 hr.
and they can adjust the fan height so it doesn't block the memory stick
I got the reviews from youtube. I really don't know what is NOT to like. Out of interest, I'm currently using a very similar Noctua dual fan + dual heatsink 14 cm x 2 (I have 2 Xeon), I have been using this for 3 yr. And I'm very happy w/ it.
