Using a Sapphire HD5870 with a Danger Den Summit 5870/5850 block.
This was my first time trying water-cooling so went with relatively cheap parts in custom water cooling terms.
Using a Swiftech MCR320 with 3 120x38mm 1,000rpm Scythe Ultra Kaze fans, an EK Dual Bay Spin reservoir, a MCP 350 pump with black 3/8-5/8 Primochill tubing.
I just stuck the included screws that came with the pump through the bottom optional fan vents in the bottom. I'm planning on moving it up to the main compartment probably above the psu after drilling a couple holes. Can't put the dust filter in the bottom how it is now.
Just waiting on a aftermarket top that I can use G1/4 barbs with for the pump. That's why I left plenty of slack in my tubes cause I knew I'd move it around, especially as I plan to get a X58 board and i7 cpu very soon, and want to WC the northbridge and cpu in one loop, and add another for just the gfx card.
