How many MB/sec (fast) does content transfer to a iPad Pro 2022 ?
ng4ever
Thinking of getting the 2 TB one but only if it transfer content as quick as a portable hard drive I have.
My portable hard drive does 110 to 120MB/sec transfer speed.
Doubting the iPad Pro does that but could be wrong.
FSCDiablo
What pendragon1 stated, but with more detail:
Charging and Expansion
Thunderbolt / USB 4 port with support for:
Charging​
DisplayPort​
Thunderbolt 3 (up to 40Gb/s)​
USB 4 (up to 40Gb/s)​
USB 3.1 Gen 2 (up to 10Gb/s)​
bigddybn
The iPad will likely blow the doors off of your external hard drive but not in the way I'm guessing you'll try to use it. Also given some of your post history.... I'd stick with the USB hard drive.
MrGuvernment
Unless they changed something in the 2022 model, while sure you can get your 100MB+ easily, the previous models was doing pretty crappy at 500MB/s
https://wccftech.com/m1-ipad-pro-thunderbolt-3-data-transfer-speeds/
Could be heat limitations, or just throttling to keep heat down...
I mean, Apple is still limiting the new 10th gen Ipad to USB 2 speeds... like really? You put in a USB-C connector, but keep the same chip and on USB2 speeds? I know most will use wifi, but those times when maybe you do want to move a boat load of items over via a faster method, oh well! Apple, innovators apparently...
