erkan said:Im on a cable, that can run 400kb/s if its a really good server, how long to download Hl2 Silver through steam? Im debating to get that or the retail( I want to play at midnight ). Thanks dudes.
k1pp3r said:ok, i have a related question for this. Can i buy HL2 via steam then have a friend burn the install files so i don't have to spend a day downloading them? And then use the key i get when i buy the game via steam?
[RCKY] Thor said:Or you can just use the steam backup utility and make your own install disks.
superthrawn said:Probably not...usually, the installation keys aren't uniform across the board...or piracy would be uber easy. The install key you purchase likely isn't going to be the same install key that would work with the copy of the game that he downloaded...
CatsGoMoo said:Actually, it isn't going to work like that.
The copy protection is checked vs a steam account.
The key that the retail versions have are then applied vs the steam account of the owner. Everybody that buys half life 2 will have to register a steam account.
In other words, I could download it anywhere, and play it anywhere, but unless someone else knows my steam account and password, they wouldn't be able to play it later. However, if someone else has a steam account that has half life 2 paid for, then they could also play on that computer without having to redownload it.
k1pp3r said:so can i use someone elses install files with a key that i purchase? From what you are saying the answer would be yes, i think it would be to much of a pain to have unique install and activation keys
GOD'SlittleSERVANT said:paul just buy the fuckin game
