works fine
why wouldnt it?Even with Firefox, Thunderbird, and other actual x86 or x64 programs ?
Firefox will have arm version, otherwise you are better looking for each important program how they work via x86 emulation. Easy arm replacement should be possible to find for something like an email client (outlook for example, microsoft app will tend to have native arm support)Even with Firefox, Thunderbird, and other actual x86 or x64 programs ?
Are you sure you want an Arm tablet instead of an x86 surface ?
lol this has been going on for like two years... what about this macbook? what about this tablet? what about an ipad? what about this....Are you sure
then my first answer stands. /thread.I do want a x86 surface
In that case you are pretty much buying a simple regular x86 laptop in a different shape, yes all your regular x86 windows app should run well on a 12th gen Intel core i5 or i7.I do want a x86 surface
