system in profile
max fsb:
-lower the cpu multi to 7
-lower ldt multi to 3
-lower memory speed from 400mhz ddr to 200
-increase fsb by 5 mhz increments
-run orthos-test cpu (i like orthos better than prime 95 ) for 2 minutes every increment once i reach 230mhz or so
-once unstable, back down 5%
max cpu:
-max cpu multi
-ldt to 3
-memory to 200
-start at fsb 200 and raise frequency in 5mhz increments up to the fsb max, or until i fail to boot into windows or post
-same orthos testing process-test cpu
-once first unstable frequency is found, back down 5%
-try bumping the voltage by the smallest increment. if i find very small overclocks, i'll keep voltage stock.
max memory (here is where it gets tricky for me):
-start with 1t
-ldt to 3
-cpu multi to 7
-raise fsb up to max or until i fail to boot into windows or post
-test with orthos-test memory
-find first unstable frequency, back down 5%
-do the same process over with 2t and try to find a worthwhile result
(should i try bumping voltage to 2.7 or 2.8? is this save with my mushkin value memory with no fan blowing on it?)
i'll figure out what to do with the results once i get them!
anything i should change in my process?
max fsb:
max cpu:
-max cpu multi
-ldt to 3
-memory to 200
-start with 1t
-ldt to 3
-cpu multi to 7
