LigTasm
- Jul 29, 2011
I've been trying to figure out a way to quiet down my XFX Vega 56, which has a Nano PCB and there is nothing available for it. I decided to try and find a universal block that had Vega mounting holes instead of trying to mod an intel asetek bracket, so I found one on perf PC's that listed Vega compatibility and bought it.
Only... this isn't a universal block. Its a universal block WITH PUMP inside. What the hell? I never knew such a thing existed, I glanced at the picture and saw a wire pigtail and assumed it was for an LED. Supposedly it can powerr a small loop by itself so I'd guess its about as powerful as a DC-LT.
Has anyone used one of these? I'm going to use it in its own loop with a spare 360 radiator and see how it does I guess, I just thought it was very cool. I may end up having to revive my plans for my phanteks mini ITX build now.In my mind thois opens up a lot of options for a small build since you won't have to stuff a pump somewhere.
Anyways, I took the cold plate off to take a look and see what was in there, so I figured I'd share because I haven't been able to find any information about this thing at all, other than that its similar to the ones in the Eisbaer line.
