How far can my old power supply go?
Discussion in 'Power Supplies' started by MNOB07, Nov 20, 2011.
  1. MNOB07
    MNOB07 [H]Lite
    90
    Feb 13, 2006
    I have an FSP Group AX400-PN. I'm looking to build a new rig for relatively cheap and while the motherboard (AM2) is a lost cause, was thinking I can get away with the power supply... although now that I'm looking around at the power supplies typically being used even in mid-range rigs I'm doubting that now.
    My question: is it possible to keep using the old power supply for a new computer? I'm looking to spend around $400-$700. Needs to play Skyrim and Diablo 3 well...
  2. artika23
    artika23 [H]Lite
    108
    May 12, 2010
    If you needed a heart transplant would you want one from and old body or a newer one? You can get a good new power supply that doesn't break the bank. Also they come equipped with the necessary connectors for a newer build which your old one may not have.
  3. leeleatherwood
    leeleatherwood [H]ard|Gawd
    1,582
    Sep 6, 2011
    If 400w is enough and also has the right power connectors, run it.
  4. MNOB07
    MNOB07 [H]Lite
    90
    Feb 13, 2006
    I've been out of the loop for awhile. Buying a new one felt more like buying a new hdd (I have a 400GB SATA) - nice but the new capacities and types don't directly fit my needs. And: poor college student.
    I didn't know PSUs changed power connectors, I also hoped I could get a formidable computer w/ the same energy draw as my last one.
  5. Dangman
    Dangman Ninja Editor SuperMod
    46,062
    Dec 15, 2005
    I would not reuse that PSU for a few reasons:
    1) It only has 23A on the +12V rail which is fairly low for a modern gaming system. Unless you're using onboard video or a very low power video card as well as a very low power CPU, the PSU may not have enough power for a modern setup. Considering that you want to play Skyrim well, that means a beefier GPU.
    2) It's rather old
    3) It's of so-so quality IIRC.
  6. Tsumi
    Tsumi [H]ardForum Junkie
    12,982
    Mar 18, 2010
    $700 is plenty to fit a good power supply in with a decent gaming rig.
  7. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    My old PSU is an Enermax Galaxy 1KW, bought new over 3yrs ago, never gave me a problem running in SLi but my Electric bill was always high, i was unemployed for most of the time so it was nearly always on.
    Now i'm gonna do a new build using an X79 system running 2xGTX 560Ti's so the PSU doesn't need to be any higher than an 750 PSU does it?
  8. Tsumi
    12,982
    Mar 18, 2010
    Your electric bill is due to your components. That power supply is fairly efficient, consistent 80% efficiency based on JonnyGuru testing. The only way to lower your electric bill is to get lower power components, or a more efficient power supply. And that would mean getting at least a 80+ silver power supply in your case.
    750 watts should be fine for a 560Ti SLI X79 system.
  9. pitbull46
    pitbull46 Limp Gawd
    210
    Feb 8, 2007
    Much appreciated, thnx.
