how do you send large files.
Discussion in 'Networking & Security' started by Ph0s5ph0L1p1D, Dec 31, 2004.
  1. Ph0s5ph0L1p1D
    Ph0s5ph0L1p1D Limp Gawd
    257
    Nov 21, 2004
    Ok well I have this zip file I want to send to a relative is there anyway I can like upload it onto a website or send it through like an atatchment? its around 140MB. PLease I am in need of your help.
  2. Cheetoz
    Cheetoz [H]ard|Gawd
    1,972
    Mar 3, 2003
  3. XOR != OR
    XOR != OR [H]ardForum Junkie
    11,549
    Jun 17, 2003
    I just stick on my website and let people download it.
    Of course, my website sits on my local network. So that kinda makes it easy
  4. Deadlierchair
    Deadlierchair [H]ard|Gawd
    1,400
    Jun 12, 2003
    Damn! That's a really really good idea! I'll have to remember that link whenever I want to send something.
    If you can't get that to work you could always use WinRar and divide it up into smaller files and then send it using Gmail accounts - but www.yousendit.com looks much easier.
  5. sigmend
    sigmend [H]ard|Gawd
    1,303
    Aug 6, 2003
    Look at the footer on their site
    "Transferring over 11,324,734,046,208 bytes per day"
    10.3 TB (10550GB) Per day? Holy shit
  6. Lethal
    Lethal ViragoAdmin Emeritus Staff Member
    28,721
    May 27, 2000
    That's pretty sweet, just bookmarked it. Thanks. :)
    It's really rough when you're on dialup and people send you huge files. At least gmail or other web-based ones give you the option to download it when you want. This sounds like a neat service, though. Thanks again!
  7. LadyJaqie
    LadyJaqie I Have No Title
    1,422
    Jun 9, 2002
    jaqiejean.mine.nu (my internet site, hosted on my own box in front of me)
    if its for public use I post a link to the file at http://foxenforums.mine.nu/
    if it isnt I send them a link, encrypt the file, yadda yadda yadda.
    by the way the 3rd of next month my second broadband connect arrives! :cool:
    once I build the load balancing server, I will have aggregate bandwidth of 6.5Mbps down and 2.25Mbps up. I will suggest to people to use GetRight or another download segmenter to get files from me at full speed :cool: :p
