Happy Hopping
- Jul 1, 2004
If I have a 3 GB img file, what's the software that can burn it to a DVD?
I have Nero 6.6, but after spending 1/2 hr. on the software, it doesn't work.
I click New, w/ the default at DVD-ROM (iso), then click Recorder, Burn IMage. But the default ext. are nrg, iso, cue.
There is no IMG. When I select ALL Files, I can pick my IMG file, but the software said something like unexpected format
http://www.daemon-tools.cc/dtcc/archive/img-files-support-rename-img-t2900.htmlyou could try changing the file extension to ".iso" then nero should see it. i've done it many times without any issues.
otherwise there's a small chance you have a bad image
