The following was updated in release sz1I:
* Improves support for CPU's with unlocked multipliers.
NOTE: CPU Fast Read is a new option that is introduced with the SZ1H/SZ1E BIOS. A setting of 'Enabled' gives the fastest memory/CPU performance. A setting of 'Disabled' is highest compatibility mode for those that experience the video corruption bug.
INSTRUCTIONS: BIOS updating can be accomplished VIA one of the below methods:
FLOPPY (Floppy Disk and Disk Drive Required)
* Download the following executable: E175_sz1I.exe
* Insert blank floppy disk into drive and run executable
* Restart machine, and set floppy as the primary boot device
* Press "Y" to program BIOS
* After flash, power off PC completely, on reboot load defaults in BIOS
CD Method (Blank CD and CD Rewritable Drive Required)
* Download the following .iso file: E175_sz1I.iso
* Use a CD Burning software to burn the .iso image onto a blank CD (Nero, Alochol 120%, etc)
* Restart machine, and set the CD Drive as the primary boot device
* The BIOS flash process will begin, Press �Y� to program BIOS
* After flash remove the CD, power off PC Completely
* Turn on the PC and load defaults in BIOS
