Snowknight26
- May 8, 2005
IE9 and FF4's behavior is identical in that respect.
Interesting. We are using the same calibrated monitors and I have 20:15 corrected vision, and I am also extremely visually picky. I assume you are using the default sharpness of 26.2%?? Turning it up I see color fringing, but at default I don't.
As an experiment, I tried going without CT again. It didn't take long before I turned it back on. I actually do prefer a couple of fonts (minority) with CT off.
But most Fonts appear bolder and more readable to me with CT ON. The CT OFF fonts look weaker thinner and harder to read at a glance.
Italic fonts in particular benefit from CT on. See italics at the top and the bottom of this comparison image. The small italics at the bottom are much harder to read on the CT OFF side.
I shouldn't have to point this out, but left is CT OFF, right is CT ON. CT ON clearly wins for me:
CT OFF --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- CT ON
Do CT haters all find the left side better?
(note: this might not be the ideal CT tuning for all monitors)
This isn't reason enough to disable ClearType of course, but it's something I'm hoping Microsoft intends to address at some point: for as hard as Gates pushed for better text rendering in Windows, Microsoft still hasn't come through on this one yet.
Not really. In FF4, you can turn off HW Acceleration and the fonts return to being just like they were in FF3. They follow the system preference and look just like they did in FF3.
IE9 removed the ability to turn off IE's font smoothing that was switchable in IE8.
Browsers can have their own settings. IE9 for example has smoothing with no setting to turn it off like in IE8. FF should more or less follow the OS settings.
