How do I remove/stop an LED on the motherboard?
Discussion in 'Motherboards' started by Trackr, Apr 5, 2012.
  1. Trackr
    Trackr [H]ard|Gawd
    1,775
    Feb 10, 2011
    So, I am going for a black-white scheme with my current build (specs in sig).
    Unfortunately, there is a Power Button next to the RAM slots that shines blue 24/7.
    What do I have to do to make it stop? I'm willing to remove the power button, as long as it doesn't risk ruining the board in any way.
    Thanks in advance.
  2. Doozer
    Doozer [H]ard|Gawd
    2,046
    May 30, 2001
    Cover the button with black model paint or nail polish?
  3. drescherjm
    drescherjm [H]ardForum Junkie
    14,475
    Nov 19, 2008
    I second this recommendation.
  4. Slammin
    Slammin Limp Gawd
    171
    Jan 30, 2005
    Electrical tape. Much less permanent.
  5. Tsumi
    Tsumi [H]ardForum Junkie
    13,030
    Mar 18, 2010
    +1 to electrical tape.
    Check your bios, there may be an option to turn off LEDs. I know my Big Bang Xpower has a bunch of LED lights showing the power phases, and you can manually turn those off.
  6. Trackr
    Trackr [H]ard|Gawd
    1,775
    Feb 10, 2011
    No, I can't cover it - it's a large button and the light is coming from every crevice.
    I am also going for a super-aesthetic thing, so I can't use nail polish, nor tape.
    I need to cut the LED power or take off the button.
    The only question is - can I do that? Will it not damage the board in any way?
  7. Tsumi
    13,030
    Mar 18, 2010
    I would not do it simply for the sake of not voiding your warranty.
    You probably can desolder it from the board.
    Have you checked your bios yet?
  8. qbanb8582
    qbanb8582 2[H]4U
    2,060
    Sep 15, 2006
    If its surface mount LEDs then something solder tweezers work very well. If they're thru hole then you'll need to desolder the leads with either solder-wick, solder sucker, or desoldering station.
    I wouldn't personally remove them as they could affect other circuits in a negative way. those circuits may need a load on them so just removing them could leave opens would induce other problems.
    And if you're not good at soldering you probably shouldn't attempt something that ambitous.
  9. Trackr
    Trackr [H]ard|Gawd
    1,775
    Feb 10, 2011
    Isn't there just a way to desolder one pin so that the LED doesn't work?
  10. KarsusTG
    KarsusTG 2[H]4U
    3,012
    Aug 27, 2010
    This
  11. Tsumi
    13,030
    Mar 18, 2010
    Your problem is, the LED is underneath a button. If you were to remove it, you would need to remove the entire unit, which may or may not have adverse consequences on your motherboard. Only a Gigabyte engineer with knowledge of the board's circuits can tell you how safe that operation would be.
  12. ChRoNo16
    ChRoNo16 [H]ard|Gawd
    1,452
    Feb 3, 2011
    Def check ur bios. The Rampage series I can shut em all off or have em on xD
  13. ninjaturtle
    ninjaturtle 2[H]4U
    2,327
    Dec 25, 2004
    Heat shrink tubing and electrical tape.
    -tape for top of button, tubing for around button housing.
    See if that works.
    Is this Mobo close to yours?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128480
    Edit: I think the button might be clipped on from 2 sides and you should be able to tape over the LED. Look at the gray housing, you should be able to lightly pry the side clips.
  14. larrymoencurly
    larrymoencurly [H]ard|Gawd
    1,624
    Jul 18, 2002
    Can you trace out the circuit board from the LED to see what connects in series with each of its leads? There's got to be a resistor in series with one of them, and disconnecting it will turn off the LED.
    Unless you have good desoldering skills and equipment, don't even think of desoldering the LED or resistor, except with a special low temperature solder called Chip Quick. I've never seen it for less than about $13. Here's a video demonstrating it: http://www.youtube.com/watch?v=FTQqjggeklo
  15. JCNiest5
    JCNiest5 2[H]4U
    3,787
    Apr 25, 2005
    I know the MSI Eclipse Plus has the option in the BIOS to turn these LEDs off. Maybe you should check under the BIOS and see if it does have the feature, too.
  16. Teerex20
    Teerex20 Gawd
    803
    Sep 25, 2002
    There are many options to cover it,i wouldn"t cut anything.Use imaginaton.Try maybe a cap of something,depending on how big it is,soda, chapstick,caps for switches-there are tons of caps at electronic supplies online - etc.
    Don"t take chance on messing with taking off,especially for warranty purposes.
