With XP or 2000 when I was terminal serviced in to a device I could hit CTRL+ALT+INSERT to mimic a control alt delete on the remote box. That doesn't seem to work on vista. How do I mimic a CTRL ALT DEL on a vista box over TS?
Are you trying to get the Task manager? You can right click on the area just to the right of the Stat Button and to the left of the quicklaunch. Then select Tas Manager.
