I just did. It's the third and fourth option down in the list, if you follow my instructions.Rtstrider said:You cannot change the icon of folder, but you can change the File Types folder...What I need is the reg key for folder
As mentioned before, my instructions will let you change them all at once. You have instructions above for changing each individual folder to something different, or changing all folders to the same icon.Rtstrider said:What I meant is you can change file folder which is right below folder...I need to find out how to change folder itself...Now I know how to click properties and going about changing each individual folder by itself...But what I want is something that will change them all at once.....
