http://www.ebay.com/itm/New-QNIX-QX...te-/121117252582?ssPageName=ADME:L:OC:US:3160
http://www.ebay.com/itm/QNIX-QX2710...3797?pt=Computer_Monitors&hash=item1e7c39ae25
So the QNIX QX2710 only has a DVI-D connection because of a bypass board for no input lag, better performance, and ability to OC. There are no other connections on it. This is what the standard board looks like, and this is basically what the bypass board looks like... note only the DVI connection and audio jack. So, I saw some triple monitor set ups of this one, like this, and this godly setup. So I got to wondering if they can be hooked up with a single graphics card. Lets say the MSI GTX 970 4G, for example. It has DVI-D and DVI-I (both dual link), along with HDMI and DP. Could two monitors be hooked up to the two DVI connections and the third to either the HDMI or DP with an active adapter? Is there any way three of these monitors could be hooked up and run normally with just one gpu? What about just two?
