How can I disable auto updates on Win10 Home?
Discussion in 'Operating Systems' started by ZodaEX, Feb 4, 2019.
  1. ZodaEX
    ZodaEX 2[H]4U
    3,647
    Sep 17, 2004
    I'm trying to test out Windows 10 Home on a second partition of my computer, but Windows 10 is downloading junk around the clock in the background and I can't get anything done. I need a way to completely shut off updates and not just delay them as my internet is so slow that the updates pile up quicker than I can download them.
  2. Executioner
    Executioner Limp Gawd
    297
    Apr 22, 2015
  3. ryan_975
    ryan_975 [H]ardForum Junkie
    13,890
    Feb 6, 2006
    Go to your networks settings and enable the metered connection option for whichever interface is connected to the Internet. This should stop Windows from automatically downloading most updates (critical updates will still come through), and stop also sharing those updates with others on the internet.
  4. Calavaro
    Calavaro Whiskey & Honey
    8,026
    Apr 11, 2001
    ZodaEX likes this.
  5. ZodaEX
    ZodaEX 2[H]4U
    3,647
    Sep 17, 2004
    This tool sounds like just what I've been looking for, thanks! My internet is so slow that I'm afraid differing them wouldn't be enough. I need to shut them up. :)
