Happy Hopping
- Jul 1, 2004
why wouldn't the motherboard, memory tec. fails?
why would anyone do this?
and is the PSU design to be soak up w/ oil?
You have to have oxygen in order for something to oxidize. Anything covered in oil no longer has a surface exposed to air, therefore it can't oxidize.and what about oxidation?
There are only 2 components I could see mineral oil destroying:
1. Mechanical hard drive that didn't have it's vent holes covered. This would result in oil getting inside with the platters and heads, and I don't think the heads would do to well with the extra mechanical resistance.
2. Optical Drives. The laser light would likely be rendered completely ineffective trying to go through oil. You likely wouldn't submerge an optical drive anyways so this would be a moot point.
And? I didn't watch the video as I'm not giving that guy anymore ad revenue.he mentions both those things in the video...he has both of them as part of his setup but they are not submerged in mineral oil
but there are far easier way to cool PC. The trouble and time spent is not worth the few deg. of temperature drop. For e.g, what happens if the component fails? How does that guy do a RMA under warranty?
Further, this is the reason that people outside the IT world see people in the IT world as nerds instead of normal people.
do you think about what you say, or do you just type in stream-of-consciousness?but there are far easier way to cool PC. The trouble and time spent is not worth the few deg. of temperature drop. For e.g, what happens if the component fails? How does that guy do a RMA under warranty?
This isn't new, by thew way. A coworker of mine (formerly known as Dr. Freeze) was doing this back in 1999.
The same could be said for custom water cooling with hardlines and compression fittings. You could use tygon and barbs. The same result was achieved. Why go through the extra trouble?but there are far easier way to cool PC. The trouble and time spent is not worth the few deg. of temperature drop.
Some people don't really care about RMAs. I bought the card, I'll use it as I see fit, and if something happens, I'll take my lumps and buy a new one.For e.g, what happens if the component fails? How does that guy do a RMA under warranty?
And we will continue not caring. I live my life for me and mine. I don't really care what my neighbors or randoms think. A lot of people's problem is they care more about a "look" than actually enjoying their life. I'm over that.Further, this is the reason that people outside the IT world see people in the IT world as nerds instead of normal people.
I am not a fan of water cooling neither. Wet Water by Zalman, the chemical inside is banned by govt. of California, as the govt. said that substance will cause cancer.
Submerged oil cooling isn't necessary at all, and comes with a lot of hassles.I am not a fan of water cooling neither. Wet Water by Zalman, the chemical inside is banned by govt. of California, as the govt. said that substance will cause cancer.
Motherboard, video card, etc. c/w 3 yr. warranty. Memory module c/w lifetime warranty. So to me, RMA is important
The other thing is, what if there is a leak, the trouble is not worth whatever the benefit is, and so far, it looks like the benefit is marginal at best
There is 2 other problems:
1) what about the smell of a tank of oil?
2) what about dust? There is always going to be dust. When dust ends up in that tank, thru time, say 3 to 6 mth., how do you clean it?
They're apparently not problems.There is 2 other problems:
oh i needed this lmao
not likely. Without something actively moving liquid across a block or heat sink, you'll end up with significant hotspots.This actually gives me an idea. I wonder if anyone's ever done a SFF mineral oil build where there's no fans and everything dissipates heat into a relatively small quantity of oil... but that oil is circulated through an external radiator? All the benefits of watercooling but with no need for blocks or plumbing inside the case!
