horrorshow
- Dec 14, 2007
Acer 23.6" 1080p TN 5ms from like 2011....
It just REFUSES to die.
Hell, yeah. Bought one of these myself when it was brand new. Still works beautifully. All of my monitors since have been ASUS.Step aside boys. I have this: https://www.newegg.com/Product/Product.aspx?item=N82E16824236112
Key features:
Bought in 2011
24" TN screen at 1920*1080
60hz all day baby
2 ms gtg getting it done
HDMI? STANDARD.
55" 4k C6P OLED plopped on my desk.
Are you experiencing any burnin issues? The test Rtings is currently running does not look promising, even though it would be outside the normal usage scenario. However, people in the comments are still pointing out burnin on their own units after a relatively short amount of time with normal usage.B6P here; LGs OLED lineup is solid for PC/gaming purposes, unlike most TVs out there.
With the C6P I honestly have not even noticed image retention in the slightest. I do have pixel shift on, but coming from using plasmas with the same option since 2003, I would see image retention in minutes on one and maybe after 30 minutes on my last plasma. Never burn in.
I'm pretty conscientious of taking care of the displays, but played hours of Cities Skylines recently hardly switching things up without issue.
Plasma burn in was completely overblown imo, OLED seems even more so. If you're using it for lots of MS office type work, don't get one. Games and movies, you're foolish not to if it's affordable.
Burn in while certainly possible, pretty much comes down to user error.
I've actually noticed some burn in on the B7A after some fairly heavy usage on the first day (had it on for about 16 hours straight - that's how much I was in awe with the TV). The C7P does seem to have less image retention then the B series though, at least according to rtings. Regardless, I love this TV so far. Can't wait to try out some 4K PC gaming on it this weekend.
Burn in on the first day? That's rough if you permanently damaged the display.
I just did it out of habit, but at least broke the display in for a few hours of full screen dynamic images. Probably not best to immediately start with static HUDs and max brightness out of the box.
Ok that's just temporary image retention, goes away on its own or running the clear noise tool. Leave what's causing your IR on too long, and it becomes burn in or permanent IR.I was playing around with the menu quite a bit and it did go away after a while. Haven't noticed anything since then.
115" 1080p pj from the sofa and a Rift.
Immersion ftw.
60 inch Panasonic plasma. Nothing else comes in black levels and overall image quality except 4K OLED. There is a bit of latency but I deal.
Got the new update?? Set input name to PC. Set to Technicolor if it doesn't automatically. Drops the lag nicely.
This is for a Panasonic Plasma? I don't know if I've updated in awhile. I have one of the last ones myself, a 65" VT60. My gaming PC is only involved with it when I use an extra doing HTPC duties as a Stream streamer, so maybe I'm already adding some latency, but any bit helps and I can always run a HDMI one day. I'm kind of in the boat of the guy you quoted. TV is just too good so it's kind of 70" OLED or bust for me.
What size screen do you use for gaming?
_
As for myself ... still chugging along at 1920x1200 on a 42" Panasonic plasma.
