Hover Hound Mismatches
Discussion in 'Hover Hound' started by Kyle_Bennett, Oct 30, 2013.
  1. Kyle_Bennett
    Kyle_Bennett HardOCP MasterChef Editor Staff Member
    41,788
    May 18, 1997
    We are discussing adding a reporting tool to the extension, but until we do that please post your mismatched Newegg URLs here. That way we can look at what is going on.
  2. Kyle_Bennett
    41,788
    May 18, 1997
    We caught a matching bug this morning that has been corrected. Your submissions of mismatches helped us identify those, so please point these out when you can, thanks!
  3. Decimus
    Decimus 2[H]4U
    2,537
    Jun 17, 2010
  4. DaRuSsIaMaN
    DaRuSsIaMaN [H]ard|Gawd
    1,136
    Apr 22, 2007
  5. Sherk
    Sherk [H]ard|Gawd
    1,751
    Jan 12, 2008
  6. Pitbully
    Pitbully [H]ard|Gawd
    1,181
    Nov 29, 2011
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157358
    Asrock Extreme9 Motherboard matches to Asrock Extreme 3 on Amazon
    http://www.amazon.com/dp/B005POPQZA/?tag=extension-kb-20
    I've noticed also it seems to have lots of problems matching Radeon Video cards. It almost never matches the correct model, ie: if your looking for a 6870 it will match a shitload of wrong ones or even link Nvidia cards to Amazon like GTX 670 cards. I haven't been posting them as I see them, but I'll start if it helps. Here's one I found in less than 5 mins.
    Radeon 6870 newegg
    and
    direct Amazon link is a 6450 card.
  7. Pitbully
    1,181
    Nov 29, 2011
  8. Ryleh
    Ryleh Limp Gawd
    284
    Feb 16, 2013
  9. Parja
    Parja [H]ardForum Junkie
    10,892
    Oct 4, 2002
  10. Turbo Mach 5
    Turbo Mach 5 Limp Gawd
    135
    Apr 8, 2005
  11. Zarathustra[H]
    Zarathustra[H] Really Fuckin' Old Timer
    20,756
    Oct 29, 2000
    How does hoverhound actually work?
    Does it maintain its own cross reference link database, or does it use the Amazon search function?
    I've been bitten by the Amazon search function a few times when I've been in a rush. It has a tendency of showing similar items, rather than items matching my exact search terms, causing you to buy the wrong thing if you don't CAREFULLY read the whole thing before ordering.
  12. Dimethyltryptamine
    Dimethyltryptamine Limp Gawd
    132
    Sep 26, 2014
    I can see a commercial for the Hover Hound with this song.
  13. /dev/null
    /dev/null [H]ardForum Junkie
    12,590
    Mar 31, 2001
  14. MacLeod
    MacLeod [H]ardness Supreme
    7,296
    Jul 28, 2009
  15. HeavensCloud
    HeavensCloud Oswego, not shitty as Buffalo
    7,354
    Feb 7, 2008
  16. DonInKansas
    DonInKansas [H]ardness Supreme
    6,385
    Jun 29, 2007
  17. RaRaMe
    RaRaMe [H]Lite
    118
    Jan 19, 2014
    I think you can right click the hover hound button and it will bring up a menu to report the mismatch.
  18. pek
    pek prairie dog
    96
    Nov 7, 2005
  19. illram
    illram Gawd
    747
    Sep 19, 2011
  20. Modred189
    Modred189 I'm Smarter Than You
    15,465
    May 24, 2006
  21. J Macker
    J Macker [H]ardForum Junkie
    10,139
    Jan 25, 2001
  22. Kaitian
    Kaitian [H]ardness Supreme
    5,336
    Aug 12, 2008
  23. Highwind
    Highwind [H]ard|Gawd
    1,303
    Sep 9, 2010
  24. Modred189
    15,465
    May 24, 2006
  25. rive22
    rive22 [H]ardness Supreme
    4,201
    Mar 10, 2004
  26. HeavensCloud
    7,354
    Feb 7, 2008
    Newegg PowerColor Devil 13 Dual Core Radeon R9 390 DirectX 12 AXR9 390 II 16GBD5 16GB (8GB x 2) 1024 (512 x 2)-Bit GDDR5 PCI Express 3.0 CrossFireX Support ATX Video Card: http://www.newegg.com/Product/Produ...a&cm_sp=&AID=10440897&PID=3891137&SID=rewrite
    Links to Amazon PowerColor PCI-Express Video Card Graphics Cards DEVIL AXR9 390X 8GBD5-ADHE: http://www.amazon.com/dp/B014F7A65W/?tag=extension-kb-20
    Proper link: http://www.amazon.com/PowerColor-39...keywords=PowerColor+Devil+13+Dual+Core+Radeon
