HOT ! Various 1TB NVMe with coveted E12 Controller $135 aprox retail
Status
Not open for further replies.
IdiotInCharge
NVIDIA SHILL
Unrelated to the thread but worth mentioning the Intel 660p 1TB is $109.99 at Newegg with promo code (must be email subscriber so possible YMMV). Yes I know it's QLC and the controller is not the E12, but it carries a 5 year warranty backed by Intel and it comes with Intel software.
These are more attractive at the 2TB capacity level, of which I have two; at 1TB, I'd rather go with the E12 drives (think I got a Corsair MP510?).
Also of note is that the 660p drives are still single-sided at 2TB, which made a difference for an ultrabook I upgraded.
Reactions: maro
D-EJ915
Walked into a MicroCenter and lo and behold, price of the Inland Premium jumped up $20 to 129.95! Goddamn.
The only good thing about the 'new' Inland Premium 1 TB is that it is indeed single layer, so it will fit in more laptops / badly designed Tbolt enclosures like the Wavlink.
Guess I should have bought more at the $99 pricepoint back when it was dual layer and larger DRAM.
Not that it's ever really at a great price but the WD Black 1TB drive is single sided too.
ir0nw0lf
The WD SN550 mentioned a few posts above is the same price for the 250 GB, 500 GB and 1 TB sizes as Amazon, for those who don't care for Amazon. :cool:
SixFootDuo
Ive been busy can someone please compile a short list with links to these E12 drives and I can updated the title and first post.
This is a very popular thread.
maro
... compile a short list with links....
I can accomodate this request because over the last few weeks I have watched these E12's all creep up in price. $130ish seems pretty common. Here are a few I was watching on Amazon. These are 1TB E12 based according to Maxx's spreadsheet that was mentioned earlier.
Inland $130
Silicon Power $125
Pioneer $125
MyDigitalSSD $130
Digifast $135
Sabrent $140
*Prices as of Jan 24th.
I would have been all over one of these at $100. Unfortunately by the time I was ready for a nvme drive they are where we are today.
Unknown-One
I have two of them installed now :cat:
I had to use a very, very slim flexible PCIe 4x riser to plug it into the one PCIe slot that doesn't steal lanes from either the graphics card or the onboard NVMe slot.
In this configuration, both NVMe drives are running at PCIe 3.0 4x, and the graphics card is still at PCIe 3.0 16x. Woo!
OFaceSIG
Does the adapter sit in the old slot and move it up? I'm looking at the amazon link but it's not clear how it works.
horrorshow
I saw it at $129 about a month ago at MC on their website.. By the time I got it in the cart, last one at my local spot was gone....
Unknown-One
It's a stiff riser cable that keeps its shape when bent, so the female end of the riser is just floating over the last 16x slot.
This arrangement offsets the card pretty significantly, so I used three motherboard standoffs, screwed together, to offset the PCI slot bracket mount point. Between the stiff riser and the screw, it's pretty secure.
Are you looking to do something similar with your motherboard / NVMe drive?
SixFootDuo
Can someone compile a heat spreaders list for these E12 NVMe drives for me please and Ill add them to the 1st posting. I'm sure many of you would like a compiled list. I will be sure to give you credit. Thank you in advance.
There are still many people out there that this upgrade would greatly benefit in terms of not only storage size but performance as well.
We can give new and old alike the best info out there in one location so they can make the best possible decision for an upgrade or a new build.
OFaceSIG
Just like to know my options. ;)
Nenu
[H]ardened
Interesting article on NVMe's being cooled with heat spreaders, should you, do you need to.
https://www.tweaktown.com/asktheexperts/299/install-heat-sink-ssd-tame-temperatures-bit/index.html
Nice info.
I like that they pointed out some chipset controllers on the mobo can result in lower speeds.
Unfortunately they dont conclude whether cooling is needed, none of the drives throttled during their tests.
Also, the drives they used are around the E7 era which use less power so wont run as hot as those in this thread.
It would be nice if they did the same tests on newer drives, extending the tests to show when drives throttle.
They didnt cover whether the heatsinks cool the NAND as well and whether NAND longevity is affected by cooling it.
If a heatsink doesnt touch the NAND there is no harm, only a possible help, fitting one in most systems. There is that :)
In a very cold room though, the NAND may need as much heat as possible under idle to prevent excess NAND wear. In this situ a cooler could prevent the SSD from keeping temps high enough.
Unknown-One
I've used this one on a bunch of NVMe drives with success: https://www.amazon.com/dp/B07KDDKDNN
I just cut the included thermal pads down so that they only make contact with the controller and DRAM, avoiding the flash.
bizzmeister
Just picked up this bad boy, cant wait till it gets here Friday.
Will be directly cloning my 1TB Intel 660p NVME drive immediately when it arrives.
maro
I think that Mushkin is a SMI2262 based controller, not the E12. Advertised speeds look impressive tho.
Vengance_01
Man I paid 50$ for 512 TLC Sabrent. Its not 80$$.. ouch. Any reason to move from 12.2 to 12.3 firmware?
D
Deleted member 324870
Guest
I have buy 2 PNY XLR8 CS3030 but i can not say which Firmware i have. The name from the Firmware is different. Its not show 12.x or 22.x.
Get this info from one PNY Drive:
Code:
v0.23a
OS: 10.0 build 19041
Drive: 4(NVME)
Scsi    : 6
Model   : PNY CS3030 1000GB SSD
Fw      : CS303224
LBA Size: 512
Read_System_Info_5008 error: 4294967295
Firmware lock supported [02 01] [P004] [0100]
Drive unlocked
P/N     : 511-190905323
Bank00: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank01: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank02: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank03: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank04: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank05: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank06: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank07: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank08: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank09: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank10: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank11: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank12: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank13: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank14: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Bank15: 0x2c,0xc4,0x18,0x32,0xa2,0x0,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die
Controller    : PS5012-E12
CPU Clk       : 666
Flash CE      : 16
Flash Channel : 8
Interleave    : 2
Flash CE Mask : [++++++++ ++++++++ -------- --------]
FlashR Clk,MT : 666
FlashW Clk,MT : 666
Block per CE  : 944
Page per Block: 5184
Bit Per Cell  : 3(TLC)
DRAM Size,MB  : 1024
DRAM Clock,MHz: 1600
DRAM Type     : DDR4
PMIC Type     : PS6102
Defects Early Read Prog Erase
Bank00:   13    0    0    0
Bank01:   13    0    0    0
Bank02:   16    0    0    0
Bank03:   11    0    0    0
Bank04:   16    0    0    0
Bank05:   15    0    0    0
Bank06:   16    0    0    0
Bank07:   14    0    0    0
Bank08:   13    0    0    0
Bank09:   11    0    0    0
Bank10:   13    0    0    0
Bank11:   14    0    0    0
Bank12:   19    0    0    0
Bank13:   16    0    0    0
Bank14:   18    0    0    0
Bank15:   14    0    0    0
Total :  232    0    0    0
Ce00Pl0:    4    0    0    0
Ce00Pl1:    2    0    0    0
Ce00Pl2:    3    0    0    0
Ce00Pl3:    4    0    0    0
Ce01Pl0:    5    0    0    0
Ce01Pl1:    4    0    0    0
Ce01Pl2:    2    0    0    0
Ce01Pl3:    2    0    0    0
Ce02Pl0:    5    0    0    0
Ce02Pl1:    2    0    0    0
Ce02Pl2:    4    0    0    0
Ce02Pl3:    5    0    0    0
Ce03Pl0:    4    0    0    0
Ce03Pl1:    3    0    0    0
Ce03Pl2:    2    0    0    0
Ce03Pl3:    2    0    0    0
Ce04Pl0:    6    0    0    0
Ce04Pl1:    3    0    0    0
Ce04Pl2:    4    0    0    0
Ce04Pl3:    3    0    0    0
Ce05Pl0:    5    0    0    0
Ce05Pl1:    3    0    0    0
Ce05Pl2:    4    0    0    0
Ce05Pl3:    3    0    0    0
Ce06Pl0:    6    0    0    0
Ce06Pl1:    3    0    0    0
Ce06Pl2:    3    0    0    0
Ce06Pl3:    4    0    0    0
Ce07Pl0:    5    0    0    0
Ce07Pl1:    3    0    0    0
Ce07Pl2:    3    0    0    0
Ce07Pl3:    3    0    0    0
Ce08Pl0:    4    0    0    0
Ce08Pl1:    3    0    0    0
Ce08Pl2:    3    0    0    0
Ce08Pl3:    3    0    0    0
Ce09Pl0:    4    0    0    0
Ce09Pl1:    2    0    0    0
Ce09Pl2:    2    0    0    0
Ce09Pl3:    3    0    0    0
Ce10Pl0:    5    0    0    0
Ce10Pl1:    3    0    0    0
Ce10Pl2:    3    0    0    0
Ce10Pl3:    2    0    0    0
Ce11Pl0:    5    0    0    0
Ce11Pl1:    4    0    0    0
Ce11Pl2:    3    0    0    0
Ce11Pl3:    2    0    0    0
Ce12Pl0:   10    0    0    0
Ce12Pl1:    3    0    0    0
Ce12Pl2:    3    0    0    0
Ce12Pl3:    3    0    0    0
Ce13Pl0:    4    0    0    0
Ce13Pl1:    4    0    0    0
Ce13Pl2:    4    0    0    0
Ce13Pl3:    4    0    0    0
Ce14Pl0:    6    0    0    0
Ce14Pl1:    4    0    0    0
Ce14Pl2:    4    0    0    0
Ce14Pl3:    4    0    0    0
Ce15Pl0:    5    0    0    0
Ce15Pl1:    2    0    0    0
Ce15Pl2:    3    0    0    0
Ce15Pl3:    4    0    0    0
Total  :  232    0    0    0
Maxx
These are custom-named firmware but relate to 22.5 and 22.4 (last three alphanumerals). Using newer flash but seems to have full DRAM.
D
Guest
I have flash fw 22.6 on one PNY XLR8 CS3030 but not working, its show after flash the same old fw.
bizzmeister
SixFootDuo
Update - prices creeping up because of global virus. Increase in prices could persist for remainder of 2020.
Expect your PC build to cost an additional 10 - 15% vs 30 days ago.
DooLocsta
Glad I updated my home and work PC before the new year.
SixFootDuo
Price is back up to $149 for Inland 1TB Premium NVMe. Wth tax, $165. Guys at Microcenter said they might not be able to get supply for a few weeks. Price could also get up to $179 or $189 within the month.
Status
