[HOT?] Spider-Man: Homecoming UHD -- $9.99
Discussion in '[H]ot|DEALS' started by Sherloc09, Dec 29, 2017.
  1. Sherloc09
    Sherloc09 Limp Gawd
    319
    Jul 22, 2017
  2. Archaea
    Archaea [H]ardForum Junkie
    9,098
    Oct 19, 2004
  3. Dion
    Dion 2[H]4U
    3,710
    Oct 2, 2004
    These 4K movie DL are always extremely low bitrate and meh audio. Be better to buy the 1080p BluRay for 5$ more.. Will look better and have way better audio.
    Movie was also shot at 2.8K so there is zero 4K detail. Combined with the low bitrate it will look even worse.
    Xinmosni and vegeta535 like this.
  4. bwang
    bwang Gawd
    961
    Aug 6, 2011
    Well, the REDs and CineAltas can do 4K and beyond, but I agree, a ton of movies are shot on Alexas these days, and those are only 2.8K native.
    Streaming 4K is mediocre at best though; there is only so much you can do with 25Mbps when Blu-Rays are running 100-400 Mbps depending on the resolution.
  5. IronTek
    IronTek n00b
    57
    Aug 13, 2005
    It's not apples-to-apples though. iTunes at least uses h.265 to stream UHD movies. They look pretty good. Blu-Ray is limited to MPEG2, h.264, or VC-1. Granted, you're not going to beat an UltraHD disc by streaming anytime soon, but it's not as bad as the numbers make it out to be.
    And I don't believe the 100-400mpbs figures are anywhere near accurate.
  6. 123Lanoix
    123Lanoix 2[H]4U
    3,753
    Nov 13, 2005
    hey all 4k blu-rays come with the regular blu-ray in the case. So there is no point in buying just the blu-ray. Also the 4k blu-ray has HDR and i think it looks fine. I got this for $9.99 at BB during black friday and it is a good spiderman movie.
    defaultluser likes this.
  7. defaultluser
    defaultluser [H]ardForum Junkie
    12,242
    Jan 14, 2006
    Blu Ray 1080p is 36 Mbps.
    Blu Ray 4k is 100-128 Mbps.
    The 4k streaming bandwidth is less than what you get on the disc, but it's not all that bad.
  8. rocketr2
    rocketr2 Gawd
    690
    Mar 16, 2007
    So 35mm film is less than 4k?
  9. Sufu
    Sufu [H]ard|Gawd
    1,997
    Sep 3, 2006
    I don't know what kind of blu-ray runs at 400Mbps when current triple-layer blu-ray UHD discs max out at around 100Mbps. Though the spec calls out a max of 125Mbps, I'm not aware of any movies with bitrates that high.
    https://en.wikipedia.org/wiki/Ultra_HD_Blu-ray
    IronTek likes this.
Tags:
