HOT? Refurbished Zotac 1080TI $432
Eshelmen
Zotac has THIS on sale in their refurbished lineup.
Seems like a great deal if it comes with the full cooler involved.
What do you guys think?
GPU GeForce® GTX 1080 Ti
CUDA CORES 3584
VIDEO MEMORY 11GB GDDR5X
MEMORY BUS 352-bit
ENGINE CLOCK Base: 1506 MHz
Boost: 1620 MHz
MEMORY CLOCK 11.0 GHz
PCI EXPRESS 3.0
DISPLAY OUTPUTS 3 x DisplayPort 1.4
HDMI 2.0b
DL-DVI-D
HDCP SUPPORT Yes
MULTI DISPLAY CAPABILITY Quad Display
RECOMMENDED POWER SUPPLY 600W
POWER CONSUMPTION 250W
POWER INPUT Dual 8-pin
DIRECTX 12 API feature level 12_1
OPENGL 4.5
COOLING Waterblock - with G1/4 Threads
SLOT SIZE Dual Slot
SLI Yes, SLI HB Bridge Supported
SUPPORTED OS Windows 10 / 8 / 7
CARD LENGTH 212mm x 164mm x 41mm (8.35in x 6.46in x 1.61in)
joecop120
This is an awesome card. Friend of mine has it in a microatx LAN rig. Does not overclock, but its performance and silence is unmatched for the size.
D-EJ915
Nice price since it comes with a block, only crap part is the ports are only on the GPU face and top and not on the back which is really bizarre.
They also only have 1.
sfsuphysics
Well it better be silent, it's a water cooled card with no fan on it :D Which unfortunately means you need a complete water cooled setup too, at least a pump, radiator setup.
sabrewolf732
This is decent if you need an itx card and have length constraints
otherwise I would suggest a 5700xt with a bykski block brand new for around the same ~$450, or a 2070 super and don't have to worry about water cooling.
