Hot: Inland 1TB NVMe Premium $109 w/ tax @ Microcenter
Discussion in '[H]ot|DEALS' started by SixFootDuo, Mar 6, 2019.
  1. erek
    erek 2[H]4U
    2,894
    Dec 19, 2005
    how are they holding up so far? a lot of failures? i heard toward the end of this thread that someone had a failure after abusing it
  2. lightsout
    lightsout Gawd
    1,009
    Mar 15, 2014
    Makes sense thanks folks.
  3. Maxx
    Maxx [H]ard|Gawd
    1,496
    Mar 31, 2003
    You can do that, yes, but you will be sequentially bottlenecked by the chipset upstream (DMI 3.0 = 4x PCIe 3.0).
  4. Maxx
    Maxx [H]ard|Gawd
    1,496
    Mar 31, 2003
    I actually have an old post on this that covers some of the basics but I must emphasis that it's an older post with different drives. I will be making a new one once I do my X570 build since I won't have the same bottlenecks. But in any case, it's not the CPU that's the bottleneck, it's the chipset, and further the gains in sequentials are usually not all that important unless you have other fast drives (which, again, may be limited by the chipset). The real advantage would be queue depth/IOPS but that is difficult to achieve without certain workloads (we're talking server generally). Every day or "real life/world" will be slower if anything.
  5. Maxx
    Maxx [H]ard|Gawd
    1,496
    Mar 31, 2003
    This controller will get hot with sustained writes but that's true of any drive within this class. It will throttle in the 70-80C range which is well below the maximum for ARM (SSD controllers are ARM Cortex-R). The NAND generally doesn't get hot enough for concern and actually works optimally ~40C. The drives have DRAM as well, so any failure would likely be because people don't have power protection or are overclocking to the point of instability (I don't want to harp on this last point, but let's get real, people run an hour of ROG and consider that stable which is completely ridiculous). DRAM helps with write amplification and such but potentially makes the drive more susceptible to power loss states (DRAM is volatile) as consumer drives don't generally invest in capacitors.
    Anyway, the NAND - Toshiba 64L TLC (BiCS3) - is actually not terribly resilient despite the fact the E12 drives have the highest warrantied endurance (TBW or total bytes written) of any consumer drive, even more than the MLC-based 970 Pro. In practice we're looking at only 2500 P/E oftentimes while Micron's 64L can hit up to 10K and Samsung's 14K (ask me for sources if desired). So with a standard WAF (write amplification factor) these drives are pushing it to the redline. Now, 99.9% of users will not get ANYWHERE NEAR the TBW on these drives even in 10, 15, 20 years. But if you're asking about reliability in terms of hammering it with writes, I would not expect it to live much past the TBW. (keeping in mind that, generally, TBW has no correlation with actual/raw endurance, it's chosen for warranty purposes)
    wadec22 and erek like this.
  6. StoleMyOwnCar
    StoleMyOwnCar 2[H]4U
    2,151
    Sep 30, 2013
    Normally I wouldn't invest in this, but 1TB for 100$ is good enough for me to try it I guess.
  7. YeuEmMaiMai
    YeuEmMaiMai [H]ardForum Junkie
    15,354
    Jun 11, 2004
  8. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,542
    Oct 5, 2004
    Just a heads up people. For $99 dollars ... you can afford to take CHANCES if you're on the fence. At the end of the day, it does have a warranty. Samsung's are $250 for this level of performance and size.
    I've been pushing the shit out of my 2 drives, I now have a total of 4TB Solidstate ... 4 drives ...2 of these E12's and 2 x Sata 1TB's .... trust me, I"ve written 100's of TB's to all of these drives combined, zero issues.
    Hulk likes this.
  9. Jim Kim
    Jim Kim 2[H]4U
    3,544
    May 24, 2012
    You care to provide any info on what you posted?
  10. YeuEmMaiMai
    15,354
    Jun 11, 2004
    go back 1 page and you will have all the details
  11. YeuEmMaiMai
    15,354
    Jun 11, 2004
    Well fellas this one might be gone for good now
    slick deals
    Microcenter website when you search on inland 1TB SSD
    the professional is a 2x drive and not a 4x so expect about half the raw performance.
  12. Jim Kim
    Jim Kim 2[H]4U
    3,544
    May 24, 2012
  13. StoleMyOwnCar
    2,151
    Sep 30, 2013
    In-store, the local store next to me had like 18 of them in stock when I went to grab mine. Well, 17 now that I took one of them. Still, a lot. Not a bad deal, it's faster than my current boot drive, so I shoved some games onto it. My benchmark gave me around 2.7-2.9gb/s on both read and write when I tested it. Not sure how to squeeze out that last tidbit that people are getting but I don't really care enough. My Samsung 960 EVO was only 256 GB, so whatever games I did put on it in order to run them faster, it was basically taking up a lot of the capacity. This gives me a lot of breathing room for a very low price.
  14. Guarana [BAWLS]
    Guarana [BAWLS] [H]ard|Gawd
    1,793
    Oct 3, 2001
    and the inland pro has been mentioned multiple times in this thread.
  15. MixManSC
    MixManSC ║▌║█║▌│║▌║▌█ Staff Member
    6,930
    Aug 12, 2004
  16. Gorilla
    Gorilla [H]ardness Supreme
    6,123
    Sep 14, 2007
    I would expect it to come back for web order someday once they get more stock in. Slickdeals hit them hard yesterday not realizing that it had been around this price for a couple months now. It was also popular enough on Reddit that google put it in my news feed.
  17. egyteam
    egyteam Limp Gawd
    432
    May 18, 2005
    anyone know what is the SLC cache on this drive? 24GB like the BPX Pro 960GB?
  18. Fremunaln
    Fremunaln Limp Gawd
    150
    May 3, 2019
    I can pick this up for anyone, if for some reason MC coffers decide to go full nuts with their whole "in-store" only shenanigans they love to pull and dont do the webstore way.
    LightsOut41 and chockomonkey like this.
  19. Aluminum
    Aluminum Gawd
    686
    Sep 18, 2015
    This is a standard stock item and house brand for Microcenter, it ain't going anywhere. They will yank off the website to keep it in their stores until next shipment, because they are a B&M that makes more profit having walk ins.
    Unless some "disaster", "fire" or "floods" hits a bunch of flash fabs, this is the new normal price. Until the next price drop ;)
    TBH I hope they slap their sticker on some reference E16 drives and have them ready for Zen launch, but I bet it won't come until later.
  20. lightsout
    lightsout Gawd
    1,009
    Mar 15, 2014
    After I asked if it was in store only (a day ago?) I have already seen it available to ship since. So yeah just have to be on the lookout.
    MixManSC likes this.
  21. Destruya
    Destruya Limp Gawd
    403
    Jul 15, 2007
    It's OOS at the Fairfax and Rockville store, but the Parkville/Baltimore store still has a few in stock and ready for in-store pickup.
    These are really desirable items, and if I remember, MCs get their new shipments on Tuesdays, so check tomorrow or Wednesday, since their website stock sometimes doesn't reflect the newly-stocked items for ~24 hours.
    Also, RetailMeNot *has* renewed the $5 off $30 coupon - just run a Google search for RetailMeNot Micro Center. You don't even need quotation marks - it should be the first result. If you get a cool enough cashier, they might even allow you to use more than one coupon so long as you use them on different transactions.
  22. doublejack
    doublejack Limp Gawd
    446
    Apr 13, 2015
    The store in Michigan has plenty of these in stock. I picked up one yesterday. The total came to just under $101 out the door with tax thanks to the RetailMeNot coupon.
    Now, I have to decide whether it is worth trying to fight with my MSI motherboard to image my current drive, boot off USB and write the image to the new drive. The other options are using a different PC with my boot drive added as a secondary storage drive and imaging it that way, or doing a clean install of windows. I'm leaning toward that last option because I only have a handful of apps installed and all I use the PC for is gaming, really. I shouldn't have to re-download any games from Steam if I copy them elsewhere and then back to the new boot drive later.
  23. YeuEmMaiMai
    15,354
    Jun 11, 2004
    why fight? Windows 10 took all of 10 minutes to install on my rig and it is a middle of the road one.
    doublejack likes this.
  24. Celeryman
    Celeryman Limp Gawd
    408
    Jan 16, 2003
    Man, they didn't when I was there a few weeks ago. They were fresh out. Unfortunately I live across the country so I can't drive on down.
  25. compcons
    compcons n00b
    47
    Jul 25, 2006
    $97.99 in Westmont. $105.58 out the door. Looks like the website is limiting quantity to 1 to reserve. I have had mixed luck buying multiple items in store when quantity was limited.
    I could replace some OLD 1 TB 7200 drives with these if I can get my x79 board to split the lanes for one of those quad cards. Research time!
  26. YeuEmMaiMai
    15,354
    Jun 11, 2004
    sweet need 3 more lololol
  27. Aluminum
    Aluminum Gawd
    686
    Sep 18, 2015
    I'm Sorry ;)
  28. darknite39
    darknite39 [H]Lite
    73
    Jul 26, 2011
    FYI, it's $97.99 now. WTF. I'm holding out for $75 at this point.
  29. doublejack
    446
    Apr 13, 2015
    Damn, too bad it'll cost me $15 in gas to make a round trip to the store for a price match. Even if it drops another $10 it wouldn't be worth it for me.
  30. acquacow
    acquacow Limp Gawd
    424
    Mar 7, 2016
    ROFL, Violin finally gave up on their own flash products and is partnering with a competitor... oh that is grand.
    They only spent 100% of their R&D budget on marketing to try and destroy Fusion-io every year... they should have spent it on products.
    honegod and erek like this.
  31. CruisD64
    CruisD64 2[H]4U
    2,102
    Mar 6, 2007
    It's back at 97.99. This is just crazy...I dunno why, but it feels wayyy cheaper than the $99 I just paid. :p
    chockomonkey likes this.
  32. Maxx
    Maxx [H]ard|Gawd
    1,496
    Mar 31, 2003
    Should be the same, approximately 30GB.
  33. wadec22
    wadec22 2[H]4U
    3,834
    Jul 26, 2005
  34. erek
    erek 2[H]4U
    2,894
    Dec 19, 2005
    i just ordered my 2nd one after you mentioned this... is it possible to do RAID0 NVMe M.2 PCIe x4 on most motherboards? does the hit to latency make RAID0ing not even worth it? just curious
  35. YeuEmMaiMai
    15,354
    Jun 11, 2004
    i have 2 going to get one more today
  36. Maxx
    Maxx [H]ard|Gawd
    1,496
    Mar 31, 2003
    Well, according to this review, specifically this image of CDM, the 256GB SKU has only 238GiB of user-accessible space (the AS SSD image also matches this). This is 256GB, while the raw NAND will be 256GiB (275GB). Then I looked at screenshots from Amazon reviews for the drive showing the other models - 512GB, 1TB, 2TB; they all show normal amounts of overprovisioning in that respect.
    I know the author (Chris Ramseyer) and he's well-versed in SSDs so I'm not sure what's going on here. However, it's quite common for consumer SSDs to have that normal 7% of OP (just going GiB to GB), the other two drives he reviewed (MP510 and BPX Pro) do indeed have additional overprovisioning to 960GB (actually 894GiB of user space), so maybe some confusion there? I generally refer to this difference as marketed overprovisioning (any more than the normal 7%) which may be what he means, but that's not unusual for E12 drives if you check my spreadsheet.
    Anyway, OP or not, simply leaving some free space is generally sufficient with a modern consumer drive.
  37. Maxx
    Maxx [H]ard|Gawd
    1,496
    Mar 31, 2003
    I have an older post on the subject but to give you the short version: most consumer boards will hit a roadblock somewhere when trying to do this, for one reason or another. It's usually not worthwhile because the main gain is in sequentials and IOPS with high queue depths, the latter of which can be helpful with certain workloads but I'd think you'd be moving up to a more serious motherboard/system by then (exception being the upcoming X570, different story, but I will be making a post on that once I get one). I personally DO run a stripe of SX8200s (as per my linked post) but only so I can shuttle around data rapidly between my other drives (one NVMe, a 3xSATA SSD RAID-0, and a 2x2 SSD/HDD tiered storage system).
    IdiotInCharge and chockomonkey like this.
  38. Hifihedgehog
    Hifihedgehog n00b
    4
    Jul 28, 2016
    How does the Sabrent Rocket compare with Micro Center's? I got the 2 TB model of the Rocket. But if the products are identical save for the sticker, I may request a return and save money by just getting Micro Center's 1 TB model .
  39. AnIgnorantPerson
    AnIgnorantPerson Limp Gawd
    207
    Jan 10, 2019
    RAID0 is useless and counterproductive unless you have a very specific use case like using something that is large and simple like map rendering.
    Maxx and IdiotInCharge like this.
