Hot! - Inland 1TB NVMe Premium $107.99 Microcenter
Discussion in '[H]ot|DEALS' started by SixFootDuo, Mar 6, 2019.
  1. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    No problem, figured it'd be a service to point up the Phison E12s. They're all literally the same exact SSDs with different stickers and possibly slightly altered components and flares like fancy schmancy heat spreaders (Patriot, HIKVision) or whizzbangs (Aorus LEDs)
    Just to correct a mistake (Transcend turned out to be Silicon Motion) here's a revised and up updated version:
    Inland Premium
    MyDigital BPX Pro
    Sabrent Rocket
    Silicon Power 34A80
    Corsair Force Series MP510
    addlink S70
    Seagate Firecuda 510 (not shipping yet)
    Gigabye Aorus
    Patriot Viper VPN100
    HIKVision C2000
    Galax Hall of Fame
    DigiFast Ace
    KingMax Zeus P3480
    CFD PG2VN
    There will also be a ton of these or no-name variants thereof showing up on AliExpress soon..
  2. groebuck
    groebuck 2[H]4U
    2,447
    Mar 9, 2000
    Hey Cybernook - I have the Asus version of that card - two of the 1 TB psion controllers and two HP 900xs - I have a TR4 asrock mono and I set them up in raid 0 and raid 0 - so 2tb and 1tb respectivly - odd thing is my 2tb raid 0 arrray performs spotty. Sometimes i get 2500 ish reads 6000 writes other times I get 4500 ish reads., On the flip side my two hps which are shitty solo - scream in raid 0 - they pull 3500/3500 read writes raided. Solo they were like 900/1200
  3. CruisD64
    CruisD64 2[H]4U
    2,073
    Mar 6, 2007
    Well...TL;DR.. I'm pretty happy but it took some time to get there. It was a super fun experiment!
    I have an X79 board which doesn't natively support NVMe. I had to edit the BIOS file to inject NVMe support and put it back together. There are some guides online on how to do that. Purchased a Qnine PCIe x4 add in card with an NVMe slot and put it in. Drive detected. Great! Next thing was I absolutely did not want to reinstall windows fresh so cloning was my only option. Macrium Reflect to the rescue and it should be easy, right? Not quite. Well I was cloning a RAID0 array that was originally in an X58 system which didn't support UEFI...basically it seems like SATA can boot MBR/BIOS mode but NVMe cannot. At least that's what I gather after all this. TBH I haven't spent the time confirming it, though (lazy). After some reading I realized I'd have to create a UEFI boot partition using DISKPART along with some bootrec commands using a Windows 10 installer USB. After that, voila! Boots right up and everything is intact!
  4. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    6,297
    Feb 7, 2003
    MP510?
  5. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
  6. T4rd
    T4rd [H]ardForum Junkie
    16,257
    Apr 8, 2009
    Any deals like this going for similar drives now? Need to order one this week for a new build. This one looks a bit better than the one in OP if just for the heat spreader on it, although I'm not sure if that's needed or compatible with this Asus board I think I'm going to pair it with that has a heat sink on it for M2 SSDs.
  7. custom90gt
    custom90gt Gawd
    532
    Jun 6, 2007
    Not to my knowledge, I think the Inland is the best deal right now. The Asus M.2 heatsink will work just fine with the Inland.
  8. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    Unless you believe black plastic stickers are heat spreaders (it has the black logo sticker on top and a white VOID IF REMOVED sticker on the bottom) which I guess they can be..
    Amazon has the 1 TB Sabrent Rocket down to $150 and the 512 GB is $80; Silicon Power 34A80 1 TB is $145.
    Just noticed that the 512 GB Inland Premium, otherwise known as the 512 GB version of the OP SSD is now shipping from Amazon for $75. That is a GREAT deal if you don't need 1 TB or a huge boot drive.
    https://www.amazon.com/Inland-Premium-512GB-Internal-Solid/dp/B07PB5C36M/
    Also, MicroCenter is probably hedging its bets, selling on Amazon. Odd they're not offering the 1 TB Premium in the OP on Amazon, will keep my eyes out for it though.
  9. T4rd
    16,257
    Apr 8, 2009
    Obviously I thought that was a metal panel/heatsink on the Sabrent just from glancing at it, but smart-ass replies are always appreciated. Nonetheless, thanks for pointing that out that it's a sticker. I guess I'll just order the one in OP then. I highly doubt I would noticed any performance issues on it anyways even if it was somehow overheating because I don't plan on doing large transfer jobs to/from it constantly.
  10. Destruya
    Destruya Limp Gawd
    402
    Jul 15, 2007
  11. Nenu
    Nenu [H]ardened
    18,789
    Apr 28, 2007
    These guys seriously limit their potential.
    I'm in the UK and cannot buy from them.
  12. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    Sorry if it came across as snide, but I didn't want people to think they were buying a free heat spreader when they were buying the Sabrent; when I got mine I was expecting one and I thought the label seemed too thin to have any wires in it. I took mine off very carefully to inspect it, gonna leave it off and if it ever needs to be sent in I'll just take it off the slice of wax paper I put it on and reapply.
    T4rd likes this.
  13. sfsuphysics
    sfsuphysics I don't get it
    13,689
    Jan 14, 2007
    Good god, Microcenter has zero presence in California now? I mean they bailed on Silicon Valley some time back but literally no stores? Fry's that strong of a presence here?
  14. Xerack
    Xerack Gawd
    588
    Jan 24, 2006
    I thought they had one in Tustin - Orange County...or did that close?
  15. Fleat
    Fleat Gawd
    956
    Jun 29, 2005
    Can someone with the Inland verify if this is native 4k or or 4K with 512e support?
    If you are on windows you can run this command (replace c with whatever your drive name is):
    Fsutil fsinfo ntfsinfo c:
    If Linux is your flavor (change nvme0n1 to your drive signature):
    cat /sys/block/nvme0n1/queue/{hw_sector,logical_block}_size
  16. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    I mentioned Amazon because 1) the Web Store doesn't always have stock and 2) some people have difficulties ordering from the MCWS; if you enter an address that is not to its liking or not 'approved' by its database, you can't complete the order.
  17. ShogoXT
    ShogoXT n00b
    42
    Mar 13, 2011
    You mentioned that the sabrent didn't have 512e. Does that go for all e12 drives? Or is the inland fine and has the feature?
  18. Fleat
    Fleat Gawd
    956
    Jun 29, 2005
    That is what I am trying to determine - hopefully someone with the Inland can run my command and fill us in. Not having 512e support is a pain in the ass. I have the Sabrent Rocket 2TB and it has caused numerous problems for me.
  19. illaghee
    illaghee Limp Gawd
    353
    Aug 17, 2016
    problems besides cloning? or is cloning the only issue?
    Jim Kim likes this.
  20. Fleat
    Fleat Gawd
    956
    Jun 29, 2005
    - Cloning definitely did not work for me. I have read claims that there is software that can handle it, but I didn't find any that were free to use. Windows image backup and restore also errored even though I read reports of people saying it worked
    - Proxmox did not like this drive and refused to provision it
    - Certain installers are not 4k native aware like Pop OS / Ubuntu / Manjaro which will misrepresent drive size and cause problems creating the EFI partition (Gparted works)
    - Weird application issues: Assassin's Creed Origins & Odyssey will not run on a 4k native drive without 512e (verified on multiple computers). The game will work perfectly fine on an internal or external SSD that has 512e on the same computers. This one is a real mystery - maybe Denuvo?
    That is what I have encountered so far. I anticipated some grief with the cloning but the rest was a surprise.
  21. Jim Kim
    Jim Kim 2[H]4U
    3,434
    May 24, 2012
  22. illaghee
    illaghee Limp Gawd
    353
    Aug 17, 2016
    Proxmox not liking this drive is terrible, that was my use case.
  23. nightanole
    nightanole [H]ard|Gawd
    2,016
    Feb 16, 2003
    no e12 drive has 521e. Its impossible.
  24. cybrnook
    cybrnook [H]ard|Gawd
    1,521
    Jan 14, 2013
    Sorry it took so long to those who asked:
    Threadripper 2950X + MEG Creation X399 RAID0 x 4
  25. aznpotpie
    aznpotpie [H]ard|Gawd
    1,127
    Dec 14, 2006
    Man I can't decide between going with a couple of these or spending more to get one without a SLC cache.
  26. Nenu
    Nenu [H]ardened
    18,789
    Apr 28, 2007
    I'm not touching them until there are simple ways to backup this to/from 512e drives.
    I'm not buying 2 drives so I can test a backup works or to have a functional backup drive. I use hard drives for testing/verifying.
    Not with these though.
    Who's the muppet that decided not to include 512 emulation?!
    Fleat and Hulk like this.
  27. Fleat
    Fleat Gawd
    956
    Jun 29, 2005
    I am sending my Sabrent 2TB back and I ordered an HP EX950 2TB instead. In my experience, the software just isn't ready for this in my use cases.
    It was more expensive by a decent margin. The Sabrent was on sale for $288 and the EX950 was around $350.
  28. Joust
    Joust 2[H]4U
    2,839
    Nov 30, 2017
    Very Aussie of you.
  29. Aluminum
    Aluminum Gawd
    664
    Sep 18, 2015
    Hawk Hardcase likes this.
  30. Hawk Hardcase
    Hawk Hardcase n00b
    43
    Mar 14, 2019
    Whomever picks up the P34A80, let us know what firmware comes with it. So far 12.2 seems to be the norm.
  31. Moonjock
    Moonjock Limp Gawd
    240
    Nov 24, 2008
    I have 2 P34A80 drives, they both came with 12.2 firmware.
  32. Fleat
    Fleat Gawd
    956
    Jun 29, 2005
    All of the issues I mentioned above with the Sabrent 2TB were immediately resolved with the EX950 2TB drive. For the time I wasted on troubleshooting issues that I was not sure were related to the lack of 512e, I could have bought several EX950's. Hopefully you guys have better luck.
  33. p0lish
    p0lish Gawd
    566
    Sep 11, 2002
    Fleat likes this.
  34. CruisD64
    CruisD64 2[H]4U
    2,073
    Mar 6, 2007
    Whoa. How long has this thing been $120? Even more of a steal now.
  35. Betauser
    Betauser 2[H]4U
    3,727
    Jul 14, 2003
  36. Absalom
    Absalom Gawd
    644
    Oct 3, 2007
  37. AXm77
    AXm77 Limp Gawd
    129
    Jun 4, 2012
    New batch from Microcenter have 12.2 firmware.
  38. CruisD64
    CruisD64 2[H]4U
    2,073
    Mar 6, 2007
    Is the firmware upgradable on ones we already have? I picked up one of the 512GB ones also and the performance isn't great. I'm wondering if a firmware update would help.
