Hot! - Inland 1TB NVMe Premium $104.99 Microcenter
Discussion in '[H]ot|DEALS' started by SixFootDuo, Mar 6, 2019.
  1. custom90gt
    custom90gt Gawd
    532
    Jun 6, 2007
    As long as you don't care about a warranty that may work. There still has to be some airflow over the sink because it will just get heatsoaked in a short amount of time. I would go with double sided thermal tape if considering doing something like that so you can remove it if need be.
  2. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    wut?
  3. eclypse
    eclypse 2[H]4U
    3,053
    Dec 7, 2003
    He means when the drive is writing to itself and not reading. Writing it gets hot.
    Jim Kim likes this.
  4. Tricyclthief
    Tricyclthief Limp Gawd
    307
    Aug 12, 2011
    Thanks for the suggestions, i definitely care about warranty and ended up sending it back. Trying another brand to compare performance.
  5. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    Thanks, slow morning for me.
    I thought he meant the writing printed on the chips lol.
    LightsOut41 likes this.
  6. LightsOut41
    LightsOut41 Limp Gawd
    445
    Mar 5, 2017
    Ditto. Thought the same at first. lol
    Nenu likes this.
  7. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    I ordered a heatsink off of amazon for the inland one - since my 2tb intel will just be doing storage etc. Will see if it helps.
  8. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,523
    Oct 5, 2004
    so are we having heat problems because of how incredibly fast this SSD is? Has anyone been doing before and after testing? Results? I'm curious.
  9. tangoseal
    tangoseal [H]ardness Supreme
    7,580
    Dec 18, 2010
    Speed doesnt translate to heat. Voktage and resistance to current does.
    Anyways my microcenter 1tb hits about 50 to 60c at peak which is very cool for Nand. Idles at around 35c which is my avg case temp. If you want best nand data retention it should float around 50c all the time. The controller likes cool not hot. The nand likes hot not cool.
    Remember what is steaming piping hot to our skin and senses is cold to other things. Like a car motor at op temp is boiling hot and unbearable to people but to a car it's in a sweet comfortable spot.
    Honestly if the vendor/manu wanted a heatsink or thought it necessary it would have come with one. Stop getting wrapped around the axle over ssd cooling.
    Jim Kim likes this.
  10. Kajun614
    Kajun614 Limp Gawd
    148
    Jul 7, 2016
    Got mine up and running yesterday. Not disappointed at all!!
    Jim Kim likes this.
  11. Jim Kim
    Jim Kim 2[H]4U
    3,498
    May 24, 2012
    I, for one, won't be spending an additional red cent on this inexpensive component. I will benchmark it after a clean Windows install and enjoy it's state of the art speed until it takes a dirt nap or I upgrade. whichever comes first. :whistle:
    tangoseal likes this.
  12. MyNameIsAlex
    MyNameIsAlex Limp Gawd
    313
    Mar 10, 2019
    Make sure you get those 50 dollar fans too lol
  13. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
  14. Jim Kim
    Jim Kim 2[H]4U
    3,498
    May 24, 2012
    Just make note of what oMek ran into w/different chip heights. You wanna cool the controller, not the memory.
    The part you ordered says it is compatible with all single-sided drives, the inland is double sided.
  15. SixFootDuo
    5,523
    Oct 5, 2004
    Your logic sounds legit. I came to this conclusion long ago. But, you never know. Some of you guys are hard-core where you leave no stone unturned which I really do appreciate. I was just making sure some new data didn't come to light that I needed to address.
  16. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    Speed increases current flow of some components proportionally.
    His statement is wrong.
    If you increase a GPUs speed (or any processor) 10% it will use approx 10% more power.
  17. Joust
    Joust 2[H]4U
    2,925
    Nov 30, 2017
    Nah. Plenty doesn't scale in a linear fashion. Efficiencies drop.
    Slash3 and Jim Kim like this.
  18. SixFootDuo
    5,523
    Oct 5, 2004
    I mean, if I have to I can apply a little tiny copper heatsink to the controller on this SSD but I bet that would be a waste of time.
    Regardless I love that you guys are eating this little gem of a 1tb NVMe SSD drive up.
    Pretty 'f'king amazing for the performance and value. Cannot be beat .... period.
  19. Jim Kim
    Jim Kim 2[H]4U
    3,498
    May 24, 2012
  20. Tricyclthief
    307
    Aug 12, 2011
    Not sure about the others, but my heat is either from a crap drive or my computer/mobo layout. Either way i sent it back, hitting almost 80c is just nuts. Have a different brand phison that will be here Tuesday, i'll find out if it's the controller or was just the Inland drive.
  21. tangoseal
    7,580
    Dec 18, 2010
    Speed is just a measure of what we want to qualitatively observe. It has nothing to do with physics. Speed something up slow it down... blag blah.
    We have physics formulas that answer all of the above.
    Voltage, resistance, and current are what matters. You can increase the "speed" of an object and increase its efficiency in materials and design and actually decrease heat generated. I.e. 14nm to 7nm generates less heat at the same or greater frequencies aka "speed".
    A 5 speed transmission might allow a car to go 80mph but at 3500rpm. A 6 speed transmission might allow same car to go 80mph at 2200 rpm. Its rotating less at the engine and consuming less fuel and still generating the same kw/hp output necessary to go 80mph.
    It's about design efficiency. Not speed.
    Since we cant overclock the SSD (normally) it's running a fixed parameter as far as thermals so its "speed" has no bearing on its thermal generation. That's a function of the electrical design of the actual ssd. If we were to OC the ssd somehow we would pump more voltage through a fixed and already designed substrate so current would increase but resistance would still impede the flow of electrons thus elevating the thermal output. This is because in this scenario we are forcing more electrons through the same space than it was designed. Increased resistance and more electromotive force equals more heat. I'm trying to explain this as layman's as possible.
  22. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
  23. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    When you increase the speed of a digital device you reduce its effective resistance, more current flows proportionally.
    Not sure what you are on about tbh.
  24. MyNameIsAlex
    313
    Mar 10, 2019
    He is saying faster speed with no voltage change will not affect temps?
    I don’t understand that people that think they will gain performance if they cool the drive down. All you will do increase lifespan
  25. Jim Kim
    Jim Kim 2[H]4U
    3,498
    May 24, 2012
    The concern is that the controller is throttling due to temp which in turn would slow it down, so in that case proper cooling would indeed cause a performance increase.
  26. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    The problem is the drive will throttle (reduce its speed to reduce power consumption) once it reaches a certain temp.
    Cooling the drive will increase performance by reducing the amount of throttling.
  27. tangoseal
    7,580
    Dec 18, 2010
    I have no idea what you are trying to state by saying, increasing speed equals more heat?
    Then how the hell do you overclock an SSD? You gonna hack the firmware and increase the clock speed of the controller? Then by all means have at it.
    Going from last generation to a next generation increases speed but it doesnt increase heat (in almost all cases) because new efficiencies in the design and silicon etc... lower thermal output and increase throughput.
    So your arguing at this point to save face and nothing more unless you have something to add that explains why an increase in throughput from last gen Inland drives vs. this generation inland drives translates to more heat? We went from 2x pcie lanes to 4x pcie lanes and a brand new controller design was implemented? Temperatures remain the same from the old gen to the new gen. Yet the throughput has increased by factors more.
  28. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    Basic facts for the same silicon.
    Not sure what you are on about.
    Many different methods reduce heat/power consumption.
    Die shrinks primarily.
    Make up what you like.
  29. MyNameIsAlex
    313
    Mar 10, 2019
    Do we have any evidence to support these concerns?
  30. tangoseal
    7,580
    Dec 18, 2010
    I wasnt attacking you by suggesting saving face... I do it all the time, save face, its the American, Western World way man!
    If you want the skinny on it ...
    The Phison E8 in the old 1TB uses about 3 watts at max load @ 3.3v
    The Phison E12 in the new 1tb uses about 7.5 watts at max load @ 3.3v
    yet the operating temperatures listed on their site is the same exact 0 - 70c.
    If you own both, and I do now, the op temps are so insanely close to one another I am not sure how these numbers even translate to more heat or less heat. Its funny (not you) but the whole numbers game they are posting vs. real world.
    The jest of what I have been saying is, who the F cares. If you can actually hit 70c and hold it there then your using the drive like its meant to be used. Toss a heatsink on it if you like. Most motherboards have built in nvme heatsinks already. The only functional heatsink I have seen is probably the one of the WD 750 Black Edition probably because I understand it is made by EK(?). Unless your going to be storing data on your SSD for the next 96 years maybe getting the perfect op temp is suggestable, but by the time even 1% of the NAND lifespan is used, I bet 99.9999% of SSD owners would have changed their drive twice over by that time. I have a 960 pro I have written the library of congress worth of data probably 20x and it just now hit 99% life span remaining.
    Here they are snake oil:
    https://www.techpowerup.com/230293/msi-m-2-shield-is-snake-oil-say-tests-company-refutes-charges
    But Tweaktown swears they make a difference:
    https://www.tweaktown.com/articles/8599/investigation-heatsinks-worth/index.html
    Hey if you get a heatsink just blow air on it to make it work right I guess.
  31. SJetski71
    SJetski71 [H]ardForum Junkie
    14,444
    Sep 6, 2002
    I didn't see this posted so ... $5 off Microcenter coupon link.
    You can pull it up on your phone's browser and present it to the cashier.
    Brings the price down to $129.99 for 1TB, and $69.99 for the 512GB
    How tempting is that?
    Anh N. and DogsofJune like this.
  32. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    Yes, the drives throttle when they reach a certain temp.
  33. Nenu
    Nenu [H]ardened
    18,883
    Apr 28, 2007
    Operating temps on different silicon are not proportional for the same speed.
  34. DogsofJune
    DogsofJune 2[H]4U
    2,742
    Nov 7, 2008
    It’s gist, not jest..... ;)
  35. tangoseal
    7,580
    Dec 18, 2010
    you are correct!
    Nenu I recommend you try this drive. you will love it regardless of the power to heat to blah blah! Its a damn spiffy and quick drive.
    better than this old piece of s&&t 128GB Inland nVME on this 2600x im typing all these useless replies on:
    here is the new 1tb with only 200'ish GB free left on the drive (I have been slamming it all day with h265 conversions non stop).
  36. Jim Kim
    Jim Kim 2[H]4U
    3,498
    May 24, 2012
    nope,
    we do have one example that lowering the controller temp from 80 to 40 did absolutely nothing. see post #234
  37. SixFootDuo
    5,523
    Oct 5, 2004
    I think this is at least worth while for a few of you to take to task and report back.
    I would also be careful with reported motherboard temps on the SSD, I think I've read this number is often not correct? I'm seeing numbers / temps from 45c idle to 58c in-use.
    Maybe a heat probe. But would be interesting to get some numbers and facts back into this tread just so everyone is up to date with these numbers.
  38. Hashiriya415
    Hashiriya415 [H]Lite
    104
    Mar 17, 2019
    I just bought a 660p. But now that this is just $35 more. Should I return my 660p for this instead? Mostly gaming, light video editing
  39. Morphes
    Morphes 2[H]4U
    4,023
    Jul 16, 2001
    I got the 1tb, pretty stoked
  40. troisanh
    troisanh [H]ardness Supreme
    7,057
    Dec 27, 2005
    anyone got spare 1T drive they wanna sell PST. 1TB nvme m.2 premium to be exact.
    no microcenter nearby and can not order online anymore.
