Hot! - INCREDIBLE!!!!! Inland 1TB NVMe Premium $99 Microcenter
Discussion in '[H]ot|DEALS' started by SixFootDuo, Mar 6, 2019.
  1. MyNameIsAlex
    MyNameIsAlex Limp Gawd
    313
    Mar 10, 2019
    Keep checking ebay, there was a BNIB Inland 1tb for $120. I almost bought it but I care more about putting money into GPU right now
  2. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,527
    Oct 5, 2004
    Yes, return it or sell it to a friend or update a Family member who isn't so concerned with the top performance tier.
    This drive has numbers as good as the Samsung 970 Pro. I know, I have the 512gb 970 Pro.
    @ $135 .... it's an incredible steal.
    The 1tb NVMe 4x Samsung 970 Pro is $375
    This drive beats the Samsung 970 Pro in 40% of those numbers from what I've personally seen.
    eclypse likes this.
  3. Kajun614
    Kajun614 Limp Gawd
    148
    Jul 7, 2016
    My local one sold out over the weekend. But the other 2 stores have 7 in stock each location.
    Local store went from 10+ instock on Weds to Sold out Sunday. They even sold out of the SanDisk Extreme PRO 1TB 3D NAND PCIe NVME Gen 3 x4 and they had a bunch of those. (dunno if same controller or not? but was $149 last week)
  4. Kajun614
    Kajun614 Limp Gawd
    148
    Jul 7, 2016
    I'm running it like it came. Figure I should be fine.
    Jim Kim likes this.
  5. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    Maverick!! :)
  6. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    So interesting - I have two 512 GB spg NVME drives in my laptop - both have the 12.1 firmware -I ran the CDinfo and got these results - but the one thing is - it never got above 40 degrees C
  7. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    ran it on my second drive as well pretty much the same results - never got above 46 C - so I am guessing it is either a spec problem on the interface or the drive itself??
  8. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    Okay this in interesting. So I updated my drivers via the intel site. Now...it hits well above 70 C and I get this
  9. 86 5.0L
    86 5.0L [H]ardness Supreme
    6,835
    Nov 13, 2006
    Whats a good SSD->SSD cloning software these days?
    Intel driver?
  10. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    odd - okay I have two SPG 512 GB drives in my laptop before I updated both were running as seen - now the C drive still performs the same but the secondary now hits 70C etc and throttles...
  11. Tricyclthief
    Tricyclthief Limp Gawd
    307
    Aug 12, 2011
    I'm thinking some people just got lucky with their drives, the Microcenter website actually shows the specs as Read Speed 3,100 MBps / Write Speed 1,900 MBps. Here's my speeds, which fall inline with the specs, i just don't like the crazy high temps i'm getting on it. I'll see how the speeds are of the Silicon Power drive i ordered with the same controller, they list the specs as Read Speed 3,200 MBps / Write Speed 3,000 MBps and carry 5 year warranty so fingers crossed.
  12. Tricyclthief
    307
    Aug 12, 2011
    I've wondered if there was some issue with the windows driver. I'm all for saving money, but it's a little worrying when there is no software support for the drive. Maybe i'm just spoiled by Samsung.
  13. 86 5.0L
    6,835
    Nov 13, 2006
    initial tests, temps seem off? but its on a riser board infront of my Hyper 212+ cooler
    my "old" Crucial 1TB Sata SSD
  14. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    do you live in a freezer? lol 18C is sub 60 F
  15. MontyAC
    MontyAC 2[H]4U
    3,176
    Sep 6, 2003
    Looks like firmware 12.2 resolves the high temp reads. We need to download 12.2.
  16. 86 5.0L
    6,835
    Nov 13, 2006
    This might have something to do with it, open air test bench sitting in front of my cpu cooler. Now im worried the nand will be too cold
    B421A954-B895-404F-84BD-3F002C33FA5F.jpeg 2476AE33-15E6-47FD-B167-D7103E679C84.jpeg
  17. Jim Kim
    Jim Kim 2[H]4U
    3,503
    May 24, 2012
    What instagram filter did you use to achieve unbelievable levels of blur ?:notworthy:
    geok1ng, Anh N., Hulk and 1 other person like this.
  18. 86 5.0L
    6,835
    Nov 13, 2006
    The “dirty lens” one :D
    Jim Kim likes this.
  19. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    somoene said they could post it.
  20. smokin9
    smokin9 Limp Gawd
    193
    Feb 9, 2005
    I used Macrium Reflect without any problems and it works good.
  21. 86 5.0L
    6,835
    Nov 13, 2006
    Used the Crucial supplied Acornis True Image, couple clicks and a few minutes later up and running on the Inland drive. Heres the test reran as the OS drive, temps are between 26* idle with peaks of 56-58* and some random dips to 8-10*(assuming its just glitchy)
  22. arnemetis
    arnemetis 2[H]4U
    2,684
    Aug 2, 2004
    For some additional data points relevant to this conversation, here's my 512gb 970 evo I got for $127 fresh, and after 5.5 months of abuse:
    crystaldiskmark Samsung 970 Evo nvme 1gb 10-02-18.png crystaldiskmark Samsung 970 Evo nvme 1gb 03-25-19.png
    Looks like the 4k Q8T8 takes the biggest hit from being full. This thing is still only faster than my 850 evo sata ssd when transferring files using my 10gbit fiber connection to my server, and the tiniest difference in some game load times. I don't do anything to make full use of it.
  23. yossarian
    yossarian Gawd
    798
    Nov 2, 2004
    Not sure what's up with my 512 GB Inland. Other than the sequential speed the others look way off.
    It's installed in an ASRock X370 Taichi in the M2_1 (32 Gb/s) slot with an AMD 1800x.
  24. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    Those are what I get with mine (512) in my laptop.
  25. Tricyclthief
    307
    Aug 12, 2011
    Whats the temps on it?
  26. tangoseal
    tangoseal [H]ardness Supreme
    7,604
    Dec 18, 2010
    The 512GB Inland only has 2x PCIe lanes and the 1tb professional model, the one this thread is about, has 4x pcie lanes and a better controller.
    Here is a comparison:
  27. tangoseal
    7,604
    Dec 18, 2010
    To further the heatsink debate let me add this data.
    So I was working on the inside of my 2600x today. Decided to take the heatsink off my cheapo Inland 128GB nvme drive, do a Crystal bench on it, then place the motherboard heatsink back on the drive and test it.
    There is 100000% throttling happening and the heatsink on this motherboard is in fact making a difference.
    Here are the results, keep in mind the cheapness and slowness of this nvme drive:
    No motherboard heatsink attached to this test. The peak temp is 60c noted by third column.
    This test was with the motherboard heatsink re-attached to the drive. Notice the speed increase and much lowered temperatures.
    THERE WAS NO AIRFLOW FORCED OVER THIS HEATSINK.
    So maybe it just hasnt had time to fully saturate and hold heat like a brick. That is about all it is.
    Now from this data I cant tell how its affecting the nand/controller. Its faster in some areas with the sink and others without it.
    Not a scientific test. Just a simple qualitative examination. If anything there is a definitive delta between the no and yes heatsink versions.
  28. Tricyclthief
    307
    Aug 12, 2011
  29. tangoseal
    7,604
    Dec 18, 2010
    Ahh I was totally unaware of that model. Well then maybe it his speeds slowing down have to do with the memory getting full. I believe most ssds slow down when they approach 70-80% full. Some more, some less.
  30. speedy523
    speedy523 [H]ard|Gawd
    1,193
    Aug 13, 2008
    just got my drive in today, and the following numbers are on a fresh, fully updated windows install where windows is not installed on the nvme.
    my drive came with firmware 12.1 pre-installed and below are the out-of-the-box performance numbers. peak temperature hit around 75*C during the upper two write tests, and stayed between 65-75 throughout the write section. temps also reached the low to mid 60s during the first two read tests.
    after this i updated the drive to firmware 12.2 and saw an improvement across the board not only for performance, but also for temps. the peak temp on 12.2 hit 65*C, however for the majority of the entire write section it stayed around 62*C. the read section was below 60*C for its entirety. these tests were also done around 15 minutes apart, so there was no change in the ambient temperature of my room.
    for those of you that havent, i would recommend updating your firmware to 12.2. my idle temps also dropped from low 30s on 12.1 to mid 20s on 12.2.
    and for completeness, my motherboard is an asus maximus viii hero alpha, with windows running the latest drivers i could find for the chipset/storage controllers. i also have no heatsink or extra airflow for the nvme specifically.
    also for comparison, a RAID0 array composed of 3 sandisk extreme pro ssds running on intel rapid storage:
    Anh N. likes this.
  31. cybrnook
    cybrnook [H]ard|Gawd
    1,523
    Jan 14, 2013
    You mind giving a quick run through on how you updated?
  32. Hawk Hardcase
    Hawk Hardcase n00b
    45
    Mar 14, 2019
    There's currently only a link to the 12.1 firmware on MyDigitalSSD's site, where did you find the link for 12.2? Or did you use the utility to capture a 12.2 firmware on a shipping drive and save it as a file?
  33. SixFootDuo
    5,527
    Oct 5, 2004
    I have a request ....
    Can someone please test with 12.1 firmware ... speeds and temps with and without a heatsink properly installed with average case airflow
    then, update to 12.2 and again, test speeds and temps with and without a heatsink properly installed with average case airflow.
    Let's establish a baseline.
    In fact, if 2 or 3 of you could do this we can establish a baseline average.
  34. speedy523
    1,193
    Aug 13, 2008
    sure thing! a japanese company called CFD also sells an nvme drive which uses the phison e12 controller, and they posted a firmware update tool on their site for their ssds. i downloaded that from here and used the setting "DLMC" for function, and "activated at the next reset" for parameter action within the program. once it was complete i just restarted and the firmware was updated. hope this helps!
  35. SixFootDuo
    5,527
    Oct 5, 2004
    How in the FK did you find this? lol .... your internet finding skillz are better than mine.
    What an incredible find.
    Hopefully they keep posting these firmware updates as they roll out.
    BTW, I've read that the firmware update is data destructive or whatever the words are. When you update, it kills whatever date is on the ssd so be prepared to reinstall everything.
  36. yossarian
    yossarian Gawd
    798
    Nov 2, 2004
    The temps at completion of testing were 47 degrees.
    This is the Premium model with PCIE Gen 3x4 https://www.microcenter.com/product...80-pcie-nvme-30-x4-internal-solid-state-drive
    Yes, that's the one I have.
  37. tangoseal
    7,604
    Dec 18, 2010
    Is it a volatile update or does data retain?
  38. SixFootDuo
    5,527
    Oct 5, 2004
    it's a volatile update. You lose your data.
    tangoseal likes this.
  39. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    well....kind of?? I have two 512s and like a boss (or an idiot) I updated both. My os drive came back my second nvme...never came back. It was there on first reboot but could not be seen in crystal disk info..second reboot, it is gone. Nothing Nada. So be careful.
  40. groebuck
    groebuck 2[H]4U
    2,458
    Mar 9, 2000
    okay third reboot it came back?? but it did not destroy my data.
