Hot, hot, hot! What to do?
GeForceX
Had a problem. Windows borked.
Fixed it with fixboot.
BIOS reports:
Old tech P4 CPU (known to be hot). Applied fresh ceramique thermal paste.
Hasn't crashed thus far though.
View of inside:
So... what do I do? Seems like there's no other way except to deal with this. :eek:
Zero82z
Nothing you can do really aside from replacing the heatsink or rechecking your thermal paste application and heatsink mounting to make sure they are both done properly.
Ocellaris
BIOS reports:
View of inside:
oh look, push pins! double check that the push pins are securely in place, make sure the fans are blowing air in the right direction, and blow the dust out of the cpu.
Posted via [H] Mobile Device
