HOT: 16GB ( 2 x 8 ) Team T-Force Vulcan DDR4 @ 3000mhz $75 AC Newegg
Discussion in '[H]ot|DEALS' started by SixFootDuo, Apr 8, 2019.
  1. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,465
    Oct 5, 2004
  2. gigaxtreme1
    gigaxtreme1 2[H]4U
    3,498
    Oct 1, 2002
  3. Burticus
    Burticus 2[H]4U
    3,825
    Nov 7, 2005
    I've had good luck with the T-force dimms.
    SixFootDuo likes this.
  4. ccityinstaller
    ccityinstaller 2[H]4U
    3,883
    Feb 23, 2007
    This is Hynix M die which should have no issues with Ryzen (even with older bios releases). I have a kit with the same timings that I initially ran at 2933c14 1.4V on a 1600 @4.1 and it was Rock solid and quick.
    On newer bios releases I can run 3200 with tightened timings. B die is going to keep that $50-75+ premium, and it's honestly not worth it once you get over 2933-3200 with Ryzen.
    I have a feeling that the cache/front end changes and the move to a separate I/O die changes to Zen 2 is going to make things even better, but that is just a guess.
    Right now, you would be better to take that extra money and buy a 512-1TB NVME SSD or bump up a GPU tier then waste it on b die IMO.
    Jim Kim likes this.
  5. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,165
    Sep 13, 2008
    these are 3000mhz so it doesn't matter if it's hynix or not they'll run XMP on any ryzen processor. it's after 3000mhz where samsung B-die matters when it comes to first gen ryzen, not as much of an issue on second gen unless you lose the IMC lottery. i currently use these on my flight sim PC (b450 w/ a 2600x) and have had zero issues with them.
  6. MrC4
    MrC4 [H]ard|Gawd
    1,306
    Feb 10, 2010
    Great to see ram prices finally coming down. Now we need this trend to would apply to GPUs!
  7. SamirD
    SamirD 2[H]4U
    2,177
    Mar 22, 2015
  8. Jim Kim
    Jim Kim 2[H]4U
    3,366
    May 24, 2012
    Thanks, you just a answered my question if b-die was still needed on the newer chipsets. woohoo
  9. dook43
    dook43 2[H]4U
    2,904
    Sep 9, 2005
    It's still needed if you want 3200+ CL14. If you don't mind slower, it isn't "needed".
  10. geforce man
    geforce man [H]ard|Gawd
    1,102
    Jan 18, 2006
    I have (I think) this exact set of ram on my ryzen 2600 server PC. Turned on, set to XMP in bios, boots and runs with zero issues. 10/10 would recommend for this price :).
  11. Hashiriya415
    Hashiriya415 [H]Lite
    104
    Mar 17, 2019
    So how much better would the b die improve gaming? Paired with 2600x
  12. Jim Kim
    Jim Kim 2[H]4U
    3,366
    May 24, 2012
    Not enough to notice.
    Hashiriya415 and kirbyrj like this.
  13. Burticus
    Burticus 2[H]4U
    3,825
    Nov 7, 2005
    Ram getting cheap enough to make me wonder if NEED 32gb in my gaming rig, LOL
