Right now i just have 1 3.5mm cord going from receiver to the computer because i lost the one it came with that had all 3, so my sub/center and rear isn't connected. I'm just using 2 speakers right now anyway and i don't notice the sub any quieter with it not being hooked up.
So my question is can i hook up my other 2 6.5''s to the same slots the ones i have hooked up right now to on my z-5500? All this will do is cut the power each speaker receives by half and make it 4 ohms, right? This would even be better correct?
If you don't know exactly what you are talking about please don't tell me anything that will damage my shit, i can't afford to replace anything. I'm almost 100% sure that the setup i have right now is fine, i have no distortion or anything, and these kenwood 6.5''s are rated 200w max 80rms.. and the z5500 set is 65wrms. Of course i literally just now plugged them in so i guess i'll know if it is damaging them very soon haha.
Also just another random question, is there any way to just increase the bass my sub puts out on youtube and games etc.? I know there's got to be one for foobar at least, i just haven't checked in a while.
