The Spyder
- Jun 18, 2002
A few months ago I started looking in to storage solutions for a virtualization project at work. After much research and speaking to several very knowledgeable people, I decided it was worth the initial investment to get a test rig together for a proof of concept. I was very impressed with ZFS and what it had to offer. Gea's Napp-It made it seem like a piece of cake to implement and I worked with a Sun admin who swears by it. I ordered similar hardware for myself to replace my aging WHS. Due to some delays, my home gear got here first and I built the following:
Supermicro X8SIL -F -O
4x4gb Kingston DDR 3 Unbuffered ECC
Intel X3430
IBM ServeRAID BR10i
1x Intel Pro 1000 PT Dual Port Nic
10x Hitachi 2tb Cool Spin drives
1x Crucial C300 64g cache drive
1x 640gb WD blue main storage drive
Supermicro 5x3.5 hard drive chassis
OCZ 600w powersupply
So far (knock on wood) this has been running flawlessly on OpenSolaris with Napp-It using vSphere 5 as my all in one host. Running 3 VM's + OpenSolaris without breaking a sweat so far.
Back to the proof of concept machine. I located a 34bay chassis with hot swap power supplies at a local ewaste recyclers and decided it fit the bill. Sadly this will bite me later. The initial config was as follows:
Supermicro X8DAH+-F-O
16gb Kingston DDR3 ECC
Xeon e5420 2.5 Quad
Two LSI SAS9201-16i controllers
10 300gb 15k SAS hard drives
10 1tb WD RE3 hard drives
2x Quad Port Intel Nics
2x Dual Port Intel Nics
After waiting for weeks everything finally showed up and I got the system assembled.
20 WD RE3 1tb :
Uploaded with ImageShack.us
Nothing like power tools to help with removing and reinstalling 20 drive cages...
16 with 4 hot spares
By thespyder at 2011-09-30
Now that 34bay case biting me? Well... Lets just say I should have bought a Supermicro 900b. I seem to have run in to problem after problem with it. First, the motherboard would not fit- It hits one of the exhaust fan brackets. Solution- remove the mounting bracket. Second, 3 motherboard studs do not line up. Solution- Grinder and plastic stand offs. Third, it required custom 8047 to 8088 cables at $29x8... Fourth, the two bottom trays for the system drives have the incorrect drive sleds. Solution: modify the sleds with new holes. Fifth, I did not like the cooling setup, so a custom 3x 120mm fan bracket has been made and is waiting to be installed. The final blow came today and it was completely my fault. It is SATA only. My SAS drives were useless. Solution: Sell the SAS drives and buy 6 2tb Hitachi drives.
For now, it is burning in over the weekend and Monday I will start benchmarking. Hopefully the rest of my memory, cache SSD, log SSD, rails will show up next week. I am planning on running a Open Solaris, Open Indian, Freenas, Nexanta benchmark gauntlet on this.
Drive setup:
8x 1tb Raid10 mirror
8x 1tb Raidz2 storage
4x 1tb hot spare (2 per pool)
2x 250gb mirror OS
2x 120gb SSD cache/logs
Questions and suggestions are always welcome.
PS if anyone would like this 34 bay chassis, I have 4 weeks before this gets racked and would happily buy a Supermicro to replace it with. www.servercases.com still sells them and parts.
A standard ATX board would easily fit and all you would need is a HP expander + controller card. 900w redundant PS with 2x 8 pin and 1x24.
Intel X3430
IBM ServeRAID BR10i
Xeon e5420 2.5 Quad
20 WD RE3 1tb :
Drive setup:
2x 250gb mirror OS
