I am closing on my first house on Monday and have been collecting components for my home network over the past month. Below are the details of my proposed buildout.
ISP: Cox Communications (22 Down/3 Up)
Modem: Motorola Surfboard 6120
Router: Symantec 1620 Security Gateway running pfSense
Core switches: 2x Dell PowerConnect 5324 24-port Gigabit switches
Patch Panel: 24 Port Monoprice
Access Point: Ubiquiti Networks UniFi AP
Mounting hardware: 4U Monoprice 19" wall-mount rack
Layout:
This is the area that I need some suggestions on. Coaxial cable enters the home in the furnace/laundry room in the basement, and I was originally planning on running all the bedroom network cables down to this area.
After further review, it may be easier to run cables through the attic and in to one of the upstairs bedrooms, which will be my lab room, housing the second switch and a 19" rack that I have yet to obtain.
Other than that, I will be running a minimum of two ports per bedroom, plus ports in the living room, kitchen, basement, and garage.
Could you folks share your home network designs and experiences? I'm looking to hear about more than just your basic modem and WRT54G setup.
Also, could you guys recommend an affordable yet decent quality spool of Cat5e? $80 on monoprice seems a bit high, and the $38 1000ft spool I got off of ebay is solid core but has really low-grade insulation that makes it difficult to strip and crimp. No need for Plenum cable here.
Once I am moved in I will start a network build log.
Layout:
