hmmm so you cant stream to your 360 if you're not connect to live?
eon
last night my internet was out so I decided to pass time by streaming movies to my 360 from my PC. But apparently this doesnt work when you are not connect to live claiming that it needs to get a codec, even though its a movie that already had the codec downloaded. So is there a way to store this locally so I can still stream when my internet is down?
thanks
Psychotext
It's a permissions issue on an media related update that you get from xbl. As I recall deleting it and then redownloading it works, but it's ages since I had to do it. There's loads of info on the net about it, or at least there was when I had the problem.
I assume it's a refurb / replacement 360?
Staples
I commonly get this error too. Used to drive me nuts until I figured out the pattern. Not connected to live will frequently give you this error. And when you are connected, everything will work fine and it will not download anything. So the error message is bs.
Possibly if this is your second Xbox, the codec may be licensed to you first console. There is a way you can transfer all your purchased licenses to the new Xbox however I think I still get the error even after I did that.
theNoid
I have no profile set to auto sign in on my 360 and I launch Media Center on the 360 and stream movies/content daily. However the feature is linked with signed content, if you are not up to date or if your console was banned from Live ... streaming was broken because signed content was is purposely disabled when your hardware is banned.
eon
yes this was a used 360 that i switched to after my first broke.
Staples
There is a place on xbox.com where you are able to switch all your old software licenses to your new Xbox. Try that and see if it fixes the problem.
Mr. Bluntman
http://www.xbox.com/drm. You can do a license transfer once a year, after that you need to call (800) 4MY-XBOX and have them do it for you, but it takes 3-5 business days. :eek:
theNoid
What does this have to do with anything? As stated, you don't need to be on Live to stream content. Basically you read the thread title, nothing else and decided it was a good decision to troll?
U jelly?
Astral Abyss
Since you guys pretty much already answered the OP question...
Speaking of streaming, I love it when I try and stream netflix to my 360 and it won't load the movie/episode, so I open it on my PC and it works fine.
hdawg06
I have this happen on my Vizio tv with web apps. I think it's just netflix devices.
