Cyberbeing
- Nov 22, 2007
HD32000 = 7K2000 in a retail box (includes SATA cable, mounting screws, and well protected packaging)
These are one sale again at Fry's as well as online with Newegg, for those that might have missed it. It's time to load up the 'ol server some more.
Been getting lots of timeout errors all of a sudden. Not sure what the deal is.
Reallocation count is not a problem.
Woulda been fucked if i had raid5.
I had the exact same situation happen both on an array of 2TB Hitachi disks and on an array of 750GB Seagate disks. Went away when I disabled all of the power management options. Like you I'm a bit frustrated by this because my arrays won't be used most of the time.well i disabled all the APM options on the Areca and i havent had any errors in about 2 hours. Im hoping that it was just that.
But kinda sucks cause my array sits idle 98% of the time.
I'll set the timer lower to check my array when I get home, but I haven't had any issues with my 5805 spinning down 8 of these drives in R6. Maybe it's just an Areca issue.
FYI...Fry's here will let you buy 4 if you ask nicely (though requires manager approval at the register).
Their 'household' detection is poor...I believe they are only aggregating based on the card you pay with. I was able to purchase 16 using a combination of my Mastercard, my wife's Mastercard (same account), my wifes Amex, and then finally my debit card. The shelf is now BARE...though I still have two more drives hidden in the store that one of my moles will be picking up later today...I hope Fry's restocks before this sale is over...guess I should go and ask for rainchecks now.
I also ordered 5 at Newegg...to get the $20 discount for EACH drive, click on the link posted in HF deals, then increase quantity to five, then click the coupon apply button. NE will only allow one deal and blocks you if you try to reorder (I tried).
I have been amasing these drives over the last couple of months...once the NE order arrives I will have 46 of these drives...which is just what I need to fill one of the two Supermicro SC847 cases I have on order (if they would only ship).
ZFS Monster hungry...need more drives.
I think it is an Areca thing as spinning down the drives in an R5 array on my Adaptec 5405 didn't cause any problems either.
Well I have six drives in a RAID6, and used the APM features, worked fine. Then I realized I hate waiting for drives to spin up (after a few weeks of using it), and just disabled it.I hope its not an Areca thing cuz I'm in process of testing 12 of these drives and I'm about to put them in raid6 on 1280ML. Would be nice to be able to use the APM
If you haven't yet downloaded the "Hitachi Feature Tool", you may want to. It's a DOS based utility for changing various features of Hitachi drives, things like APM settings, SATA speed (SATA150 / SATA300), etc. It's available on the Hitachi downloads and utilities page here (the page also has tools like the DFT - Drive Fitness Test, etc):
http://www.hitachigst.com/hdd/support/download.htm#FeatureTool
Now I've read reports that HDS722020ALA330 drives manufactured prior to a certain date were set to "SATA 150" from the factory. Among other features, the Hitachi Feature Tool allows you to set the mode to "SATA 300". If you haven't bothered to check your drive for which mode it's set to, it might be a good idea. I'm verifying my drives now because in a raid array I wouldn't want some of them at SATA150 while others are at SATA300.
EDIT: Verified all my drives (manufactured October, November and December 2009) and all were already at SATA 300.
Ok so from what I've googled (the only reviews i could find were in japanese) http://blog.yuhisa.com/archives/571
it seems that my drive with 21.41 512k reads is actually not the norm? and it should be in the ~50 MB/s range.
It is FW 20N vs FW 28A on the disk with higher reads
So a bad drive to be sent back? Or am I missing something here
I saw this performance post about the Hitachi drives:
http://www.xbitlabs.com/articles/storage/display/2tb-7200rpm_7.html#sect0
Are the 2TB Hitachi drives really the slowest non-green drive?
There's little question which is the capacity/ performance leader.
Fry's has these on sale again for 119.99 each, limit 2.
Now, the question I have is this. I have a 2T Seagate(ST32000542AS/5400rpm) drive. I'm going to pick up 2 of the Hitachi's for a software raid 5. Can I add the Seagate drive without a problem? I just make sure they area all the same size when I partition/format them right?
