Reminder: FRYS > AMAZON > NEWEGG for sourcing Hitachi drives, reason being at Fry's you get the retail box version which has superior packaging of the drive - suspended with the plastic clamshell brackets which is superior to the hitachi OEM package from Amazon (cardboard) or the infamous Newegg repackaging of individual OEM drives removed from a factory 20-pack.
The +tax you pay at Fry's is well worth it for this reason alone.
Yes, I think it seems to be. The trouble then is sourcing 4 drives from different factory runs. (Though I'm not sure how essential this is. Some people swear by it, other's call it FUD)
And again, I've been told the 5k3000s are superior to the WD Green 2TBs because they haven't been stripped of their "RAID Support" - can anyone elaborate on this, please? I know the new WDs are stripped of the TLER support in firmware - do the Hitachis still have this? I read in this thread from 5 months ago that Hitachi removed AAM from the drives through a firmware update - is this still the case?
Thanks for the feedback.
Then these are worse than the WD Greens? If they don't have CCTL and AAM, make more heat, use more energy, and have a far worse RMA process then I don't see what the benefit is.
And thanks for the link back to the other thread. I hadn't noticed there was a reply!
They are $69 online also http://www.frys.com/product/6554753?site=sr:SEARCH:MAIN_RSLT_PG
Just an FYI. I tried to order 10 of these last night and Fry's canceled the order stating the item is in "limited quantities" even though I do not see that on the site.
Just buy 2, go to your car, drop off drives, return to store, buy 2 more - go home. As long as you get a different cashier it's all good and even if not I don't think they really care.
No, their POS does not do anything like this (take this from someone who has actually worked there and knows the ins and outs of their operations). The maximum that you can buy in a single transaction is twice the quantity limit (which will need to be approved by a supervisor/manager, but that is seldom a problem).Gotta use cash or a different credit card each time too. Their POS system will track it.
Most of the time you can carry 4 or 6 to the cashier. Smile a lot and if the super isn't watching too close they'll just ring them as separate sales.
I have 10 2TB hitachi drives from newegg (5 7k3000's 5 5k3000's) - one was DOA, but I think that was because the shipping department was using it as a doorstop/hockey puck. To be fair I sent the pictures to newegg and they immediately overnighted me a new drive and emailed me a calltag for the old one at no charge, which is all I could have asked for (well, given that I got a bum drive in the first place)
Otherwise no problems/dead sectors, etc. all anecdotal of course though..
http://www.behardware.com/articles/788-6/components-returns-rates.html
BeHardware, in their return rates stats for this year have Hitachi at the lowest. More useful would be some that broke down the drives by models though.
It turns out you're 100% right about the firmware using the rest of the buffer memory. A user on another forum noticed it mentioned in the small print so got the full data sheet and found that it was actually used by the firmware. Pity Hitachi tech support don't know about the changes they themselves makeYou aren't alone. I see that on my coolspin drives, but they work fine for what i'm using them for so to me its not a big deal. I suspect the firmware may be using the rest of the buffer for something else.
LMK if Hitachi tells you anything else.
Out of curiosity, does anyone know of other hard drive brands that use the buffer memory for the firmware? Seems strange to me, especially as i always assumed buffer memory was temporary volatile memory like RAM and also other drives always show the buffer memory they state they have; maybe that's the reason (amongst others), why Hitachi are able to sell these drives for less as they don't have additional memory modules for the firmware storage? Either way, not an issue any more, just happy it's normal as i'm very happy with the drive; especially with how quiet it is compared to my Samsung HD154UI which i'm going to sell off even though it's only a few months old.hg144 said:Re comments from Xad, I think I may have found a possible reason why the Buffer size is not showing as 32MB.
I have just bought two of these drives and before they arrived I was doing some digging around for more information when I found your posts. I was a little concerned in case this indicated a possible common fault.
Once the discs arrived I formatted the first drive, and then used Crystadisklinfo and HDtune to do some benchmarks and check the drive information. Like Xad I found the Buffer size was reported in Crystaldiskinfo as 26129 KB, and in HDtune it was reported as 26756608 bytes. As 26129 KB = 26756096 bytes, I think these are reading pretty much the same.
As part of my searching for an answer I downloaded the data sheet and technical manual from the Hitachi site (http://www.hitachigst.com).
On the data sheet the specs list the buffer size as 32MB but with a footnote saying that "Portion of buffer capacity used for drive firmware".
On page 19 of the "Hard Disk Drive Specification" manual for the 5K3000 there is a table headed 4.2 data Sheet. This lists the buffer size as 32MB but again there is a footnote which says "Upper 6638.5 KB are used for firmware, this is typical value, it depends on firmware revision".If you add this figure to the figure reported by paul99 and by my HDtune test, you get back to 32MB. I think that is more than a coincidence, and probably explains why the buffer size is not reported as 32MB.
6638.5 KB = 6638.5 x 1024 = 6,797,824 bytes
6,797,824 + 26,756,608 = 33,554,432 bytes
33,554,432 / 1024 = 32768 KB
32768 / 1024 = 32 MB
The data sheet can be downloaded from:
http://www.hitachigst.com/tech/techlib.nsf/techdocs/02D9197756A273D0862577D50024EC1D/$file/DS5K3000_ds.pdf
The Hard Disk Drive Specification cane be downloaded from:
http://www.hitachigst.com/tech/techlib.nsf/techdocs/3B466EACAD15AD4E8825781D00360E58/$file/DS5K3000-2TB_CS5K2000_OEM_manual_1.0.pdf
Here's the excellent post if anyone else gets worried about the 26mb buffer memory; it's not a fault like Hitachi tech support seem to think, it's actually the hard drives design:Out of curiosity, does anyone know of other hard drive brands that use the buffer memory for the firmware? Seems strange to me, especially as i always assumed buffer memory was temporary volatile memory like RAM and also other drives always show the buffer memory they state they have; maybe that's the reason (amongst others), why Hitachi are able to sell these drives for less as they don't have additional memory modules for the firmware storage? Either way, not an issue any more, just happy it's normal as i'm very happy with the drive; especially with how quiet it is compared to my Samsung HD154UI which i'm going to sell off even though it's only a few months old.
How come they do that? Is it because it can run faster from ram rather than the other memory modules they have on the drive?I bet they load the firmware into ram. much like a router.
yesHow come they do that? Is it because it can run faster from ram rather than the other memory modules they have on the drive?
Any reason why the 5K3000 runs hotter then the 7K1000.C disk on the next right? It's always hotter.
Does it feel hotter? I don't trust the sensors in these things. I have several Samsung drives that consitently report temps well below room temperature. Inside a PC case. While operating.
Gauging temperature by feel is a terribly inaccurate way of checking. At the very least, use an infrared thermometer
Has anyone had to rma these drives to hitachi? Just curious how it went.
I just had my WHS box claim two are bad, one failed an HD tune error scan, and the other is being tested now. For the record they are both 7k2000s
also, are the hitachi retail boxes with the black inserts good enough to ship to them?
Does anyone have a link or source for the JKDL_SP firmware update tool? I first emailed Hitachi 6 weeks ago about a problem I have with my 7K2000 drives taking DAYS to defragment (when all other drives in my server defragment at normal speeds). After much back and forth with them, they determined I needed a firmware update, and finally sent me 3MA firmware and the HiTest software. But that software does not recognize my drives: neither the ones on my MB ports, nor the ones on my AOC-SASLP-MV8. In fact, it doesn't see ANY drives on my server, and sometimes just scanning for drives gives me a BSOD. I asked them if they had a DOS tool, and they said they would check. That was two weeks ago, and Adrian Cutler @ Hitachi has been ignoring my emails ever since.
I used the old dos based program from hitachi to test my drives. I never saw hitest on their site. I doubt Advanced SCSI Programming Interface - Wikipedia, the free encyclopedia would help though.
OmegaAvenger, I wasn't referring to Hitachi's diagnostic utility. Hitachi offered two programs capable of updating the firmware on 7K2000 series drives (one was a DOS utility JKDL_SP.exe, the other was a windows based application called Hitachi HiTest).
On the 7K3000 and 5K3000 series drives, Hitachi no longer offers a DOS utility (they may have a DOS tool for these new drives, but they sure aren't acknowledging it publicly). If you request a firmware update you receive the firmware with the windows based application Hitachi HiTest. From my experience HiTest is very unstable, and has been nothing but a huge headache. It only seems to recognize drives on a select few chipsets. Only Hitachi knows what chipsets are supported by HiTest and they don't offer any documentation which lists the supported chipsets,
