WBurchnall
- Oct 10, 2009
TL;DR Is there better Return on Investment for spending more these days with multi-core processors than there was 20 years ago? As now you get a direct upgrade in core/thread count rather than in the 90s/2000s where you might just get a better binding and a 5-15% increase in clock speed and slightly more cache?
I just wanted to get people's opinions on high end processors and their return on investment. I'm going to be doing a new build soon and traditionally, I tend to get processors in the $350-$400 dollar range. Mostly because in the past I noticed the 'Extreme' versions for $900 dollars more seemed to be identical in core count and just gave a small improvement in the form of say "0.4 Ghz faster" and the performance gains for the extra $900 dollars were in the range of 20%. So I always went for something mid-range for the gaming crowd as it seemed the best bang for the buck. Like my last processor likely 6 years ago was an i7-930; before that was a Q6700 and Core 2 Duo E6600 before that etc... A reasonable gap between processors.
That being said, I notice that now for $1000 you can start to get processors that have double the core and thread count when comparing it against the $350-$400 dollar processors and for $1500 almost triple the core/threat counts. So it seems like there might be a significant performance increase; especially 5 years down the road if we are moving towards programming for higher and higher thread counts.
IE 6 core(400) vs 10 core (1000) vs 14 core (1500).
I'm just wondering, what people's opinion is on what the return on investment over the lifecycle of these newer high core-count processor will be? Is it much better to spend the extra $900 now than it was a decade or two decades ago? IE those of you who bought say the Intel Extreme Edition processors back when the i7-930 was out, was it worth it? Did it help you continue to use the processor and keep it comparable to new ones long after it was long in the teeth?
I'm mostly motivated to upgrade my i7-930 as when I look at CPU-benchmarks on CPU-Boss or random websites, the raw performance per core seems to be 50% higher and 30% higher clock speeds are resulting in double the estimated overall performance at some tasks I commonly do (video conversion, gaming, SolidWorks, AutoCAD, Revit, etc).
I'm just wondering now that there seems to be almost linear-scalable-upgrades, is there any disadvantage to getting a $1500 dollar 14-core processor when intention of using it for 10 years? Will new processors have new instruction sets or something that holds it back significantly? I do know my i7-930 has limited support for x265 due to it's age relative to x265. I think it cannot natively decode 10-bit 4k and requires the software to do it during playback giving high cpu usage where one with x265 instructions barely sweats. IE a $60 dollar setup box from China out does my i7-930 at 4k 10 bit. Sad.
