Travis Simposn
- Jul 12, 2018
I seem to be getting some really high GPU temps when playing the Witcher 3 (1440p ultra settings). My average GPU temp is 87 degrees Celsius while my CPU hangs right around 45-47 while playing the Witcher.
I have an H200i with the Kraken X52. Here is my setup, any recommendations?
- X52 is open config with fans installed exposed to the front case panel.
- The top and back stock fan are blowing
- I customized the fan profile for the 1080GTX G1 Gaming to ramp up starting at 40 degrees and max out at 70 degrees
