hiding programs in add/remove programs
Discussion in 'Operating Systems' started by pircio, Mar 15, 2005.
  1. pircio
    pircio [H]Lite
    78
    Apr 18, 2003
    hi... i'm looking for a program or a way to remove specific programs from my add/remove programs window without actually removing them from my computer.
    to be more specific for you guys that need specific... i want to "hide" or "remove" SPECIFIC ENTRIES that are in "add/remove programs" so they do not populate when add/remove programs is opened... i am NOT saying that i want to remove the whole tab or add/remove programs, nor am i saying i want to remove the add/remove programs icon in my control panel, or windows components in my add/remove programs.
  2. Phoenix86
    Phoenix86 [H]ardness Supreme
    6,653
    Mar 28, 2002
    Why? Reason I ask is a lot of times people ask for something specific like this they are often heading down the wrong path, and end up with a specific odd-ball request like this. Sometimes the research is done only to find the solution won't work.
    [​IMG]
  3. OldPueblo
    OldPueblo [H]ardness Supreme
    6,352
    May 31, 2003
    My guess is he wants to hide an installation for some kind of remote software/keylogger. :D Hey I'll bite, I had to install and hide something to catch my sisters cheating husband. This could be to monitor his smart kids or something so I'll assume you aren't doing something illegal. Search the registry for the name thats listed in add/remove. You'll find a list in the registry that corresponds to the add/remove list. Then just delete the entry I believel. I'll try to find it. Back up those keys in case you want to put it back to uninstall. And tell us why of course, don't be doing illegal crap.
    Edit: Try here HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
    Once again, back up any keys you change in case you screw it up.
  4. akapaulk
    akapaulk [H]ard|Gawd
    1,315
    Jun 21, 2002
    Google CCLEANER, IIRC they have a nice inteface to do what you need.
    PK
  5. elation
    elation Gawd
    784
    Feb 4, 2003
    ***Here's how to unhide them***** Just do the reverse. Shamelessly ripped from TechTV.
    1. Navigate to C:\WINDOWS\inf
    2. Open the sysoc.inf file in Notepad or another plain text editor. If you can't find the inf directory, it's probably hidden. Unhide it.
    1. Click Tools and choose Folder Options.
    2. Under View, enable Show Hidden Files & Folders.
    3. In sysoc.inf, look for the section called "components" in XP or "old base components" in 2000. What looks like a bunch of gibberish is actually pretty easy to read. You'll see a component name, followed by an equals sign, followed by a list of parameters separated by commas.
    For example: Games=ocgen.dll,OcEntry,games.inf,HIDE,7
    4. The deal: the "HIDE" between the two last commas indicates a hidden component. Remove "HIDE" to unhide the component.
    For example: Games=ocgen.dll,OcEntry,games.inf,,7
    5. Unhide any component you want.
    6. Save the file.
    7. Reopen the Windows Component Wizard to see your new Add/Remove options!
  6. pircio
    pircio [H]Lite
    78
    Apr 18, 2003
    i have stuff installed at work that i'm not supposed to have installed....
    helpdesk asks all sorts of questions should i need to call them
    damn them not giving me admin access :)
  7. OldPueblo
    6,352
    May 31, 2003
    I feel so violated... :(
  8. eeyrjmr
    eeyrjmr [H]ardness Supreme
    4,363
    Apr 23, 2002
    "Advance System Optimiser" can do it.
    Well it can do alot of other things (very good things)
    I remove all the updates from the "add-remove" list - dion't like them cluttering it up when I really want to remove something
  9. feigned
    feigned [H]ard|Gawd
    1,224
    Jan 7, 2003
    Good advice and all, but that has nothing to do with the section that the OP is concerned with.
  10. elation
    elation Gawd
    784
    Feb 4, 2003
    I don't understand what the OP is. Please explain.
  11. OldPueblo
    6,352
    May 31, 2003
    He wants to hide something in the normal list that gets filled when you install something. As in "I took advice from some guys in the [H] forums though they didn't realize they were helping a douche bag break the rules of his work network." Not the components area where you check/uncheck stuff.
    (semi-kidding with the douche bag part) :D
  12. elation
    elation Gawd
    784
    Feb 4, 2003
    Oh. Don't won't to cheat at work and get busted. Is it worth losing your job over? or even getting written up.
    That's for windows components - doh. Don't know where the other is.
  13. Wolf31o2
    Wolf31o2 [H]ardness Supreme
    4,612
    Nov 7, 2000
    Heh... Where I work, they just replace the "troublemaker's" machine with a thin client machine, which is totally locked down on the server.
  14. pircio
    pircio [H]Lite
    78
    Apr 18, 2003
    don't worry about me, if i would have been busted it would have been months ago :)
  15. nuclearfly
    nuclearfly Limp Gawd
    262
    Aug 24, 2004
    We can all hope that his admin reads the forums..... :rolleyes:
    [​IMG]
