well really its only 4-5% faster clock for clock over the 670 so dont be fooled by the higher out of the box clocks. hopefully it overclocks a lot better though and is not simply at the edge out of the box.if its 400 im buying on release day
well the 760 ti will be a rebadged 670 so yes.I'm assuming a 760 ti will be faster than the old gtx580 by a bit?
What about TDP and heat? If its a refined version of 680, will it be quiet, consume less power and heat compared to 680 with 5-10% more perfomance?
Nvidia has yet to release a Kepler gpu at more than 1.18v. I doubt that it'll suck more juice.
I really think that they're just using binned gpus.
What I'm curious to see is what kind of overclocking headroom will the 770 have? 1300+ average boost clocks, could be realistic if the default voltage is higher.
S[H]ady;1039913122 said:I wouldn't expect there to be much extra headroom for overclocks on the 770s. They are a rebadged 680 with higher clocks already. They are already pushing that chip pretty hard, I'd be surprised if they clock higher than the existing 680s already can.
And a slight core revision, plus 7ghz rated memory chips instead of 6ghz ones.
yeah all rumors we have seen say the chip itself is just a straight up GK104 from the 680.I don't know that there is even any core revision. I haven't seen any evidence to point to that being the case.
yeah I have seen that but the chip revision number actually means almost nothing though as each card just gets a different revision number anyway. hopefully it will only be the best of the best GK104 chips that make it into the 770 though.http://videocardz.com/41646/nvidia-geforce-gtx-770-final-specifications
425 revision vs the 400 that the gtx680 uses. Rumors of course but I wasn't just making up stuff randomly .
yeah I doubt it too so it will probably only oc about 7-10% better than my card. I see no point in paying 400-450 bucks for a 20-25% upgrade over card I only paid 230 bucks for that also included a game I sold.I highly doubt that 1400mhz will be very common. The vast majority of MSI GTX680 lightnings don't hit that.
gtx280 was $650 while the next in line gtx260 was $400 and those were both on the same core. there is nothing odd about the gk114 gtx770 being $400 while the gk110 780 is $650. part of the reason the 780 is so high is to not take away from the Titan.There's just no way this card will be $400.
$1000 Titan
$650 780
$400 770
Doesn't even make sense. $250 cheaper? Has there ever been that much of a disparity between the x80 and x70 card? I mean, I know it's $350 between Titan and 780 - but Titan is an outlier...almost like a 3970x CPU...
S[H]ady;1039914064 said:There's no evidence to suggest 500 other than complete speculation.
The rumours that have been reported are saying 499.
Just because you feel that 450 to 650 is to much of a jump, does not make it 500. They would be silly to do that. They sell way more of the cheaper cards than expensive top tier cards. Last year the top tier was 500 but the same core was used for both the 670 and 680. Manufacturing costs would have been very similar, if not identical.
This time around they are using the already tried and true gk114 for the 770. Those would be significantly cheaper to manufacture than the new gk110, allowing nVidia to price the 70 cards at more affordable prices compared to the 80 cards.
They will go 450 because they can, but no higher, it would be terrible for sales. Remember, the 770 cards will have competition from AMD at the 400 dollar mark with the 7970. $100 more for 10% gain isn't going to appeal to enough buyers. The people who don't care about the money will opt for the bigger, better 780.
If they are smart, they will come in between 420 and 450. They will sell many of them at that price.
Based on what NVIDIA has done in the past few months, I say $500.
The only problem with all of this is the x70 cards are still "top tier" - they're the 2nd best card (typically) - so there's no "budget" reasoning for them to price it lower. The 760 Ti will likely compete with the 7970...so there's no reason to worry that much with the 770 part.
And yes, of course it's pure speculation.
I really hope they do 400$.
