Hey guys,
Need some help with routing tables to allow connectivity between workstations in different IP ranges within the same LAN... Or maybe an alternative to the current model I'm using.
I've attached a picture below to try and make it easier to understand. The main reason for this setup is to limit bandwidth for workstations under the PC that is doing the ICS, via net limiter. (Don't want to go the route of IPcop, etc.. And My router cannot do bandwidth limitation per IP, but it allows me to create routing table entries, etc.)
Anyway... The server, which is doing ICS has two nics. 192.168.3.2 which is used to connect to the router and it's doing the ICS with a secondary nic, which is: 192.168.137.1
The setup works and all PC's can get to shares on the server. However, workstations in the 192.168.3.x range (PC1, PC2 & PC3) cannot communicate with workstations in the 192.168.137.x range (pc4, pc5 & pc6).
I've added a custom user entry to my routing table which allows me to access the router (192.168.3.1) from a PC in the 192.168.137.x range, but I still cannot access resources on PCs across ranges, what am I missing?
The question is... How can I make these two different ranges communicate and reach each other?
Thanks...
Thanks...
