If anyone out there is familiar with gigabyte motherboards and their bios i'd greatly appreciate the help.
I recently upgraded to a Ryzen 3800x and purchased a x570 master to go along with it but i'm having two issues.
1. I flashed the main bios using Q flash and a USB to the newest version on gigabyte's website F7b, however that corrupted the main bios and i only get a black screen that won't load windows, but i am able to access the bios. When i switch to the back up bios that is the factory set F4 bios everything loads fine. I tried to flash the main bios to F6 and to F4 but the problem persists. I have complete access to the bios but it will not load windows. It doesn't even recognize the boot partition within the bios. I tried clearing cmos and set bios to factory defaults but it doesn't appear to work. Please help.
2. When i load windows through my back up bios (F4) my CPU temperature in SIV smart fan 5 is constantly going up and down in giant leaps while at idle, however other monitoring programs such as ryzen master show a constant 46 degrees. all the fans are working but something appears to be wrong with the temp monitoring within SIV.
Thanks,
Thanks,
